referential scaling?
Aug 12, 2012 3:33 AM
how can i do referential scaling, like scaling an object with reference to another? see the video. open in new tab or click on it too see the video
    Aug 12, 2012 4:45 AM   in reply to arjun2
    arjun,
    I believe a few (more) words are called for, or at least a slow(er)motion video.
    Aug 12, 2012 9:24 PM   in reply to arjun2
    Won't a copy of the object scaled work the same? Alt drag the object, then scale it proportionally.
    Aug 15, 2012 8:32 AM   in reply to arjun2
    Incredibly, sometimes a picture is not worth 1000 words.
    Select an object, double click the Scale tool... is that even close to what your'e after?
    Aug 16, 2012 8:34 AM   in reply to arjun2
    You videos and messages don't tell much, try making your video using Illustrator showing what you have done so far and also show a sketch of the final result that you can't achieve in Illustrator.
    Without this I can only make a wild guess - pick the Selection tool (black arrow), select your object and drag one of the corners of the bounding box holding Shift key down.
    Aug 16, 2012 8:47 AM   in reply to arjun2
    To scale an object to the same height or width of an other object:
    1. Select the object with the desired dimension.
    2. Copy the desired dimension (from either the height or width field in the Control Panel.
    3. Select the object you want to scale.
    4. Turn on the proportional chain link between the height and width field.
    5. Paste the desired dimension into the appropriate field.
    Two pieces of advice:
    Take the time to FULLY EXPLAIN what it is you are doing and what you need help with. I, for one, seldom ever click a video in this forum. If you don't have time to fully and clearly explain yourself, why do you expect other users to take time to try to decipher what you're talking about?
    READ THE DOCUMENTATION. You're asking about very basic functionality here.
    JET
    Aug 17, 2012 8:28 PM   in reply to arjun2
    How about simple math and the Transform Panel? If the fish eye needs to go from 2mm to 4.2mm, it needs to be 2.1 times its current size. Select the entire fish, go to the Transform Panel, click the link to Constrain Width and Height Proportions, multiply one of the dimensions by 2.1, press enter. The eye now has a diameter of 4.2mm, and the rest of the fish is scaled proportionally.
    Edit: Or, I suppose, the Control Panel.
    Aug 18, 2012 3:49 AM   in reply to arjun2
    You can use the value fields to do simple math for you.
    1. Select the object you want to use as the scale reference.
    2. Select and copy one of its dimensions (example: 21 mm).
    3. Select everything you want to scale.
    4. DoubleClick the Scale Tool.
    5. Paste into the Uniform field.
    6. In front of the pasted value, type the desired dimension and a forward slash (example: 125/).
    7. Click outside the field to commit it (example: 7.143).
    8. Move the decimal two places rightward to expess it as a percentage (714.3).
    9. Click OK.
    JET
    Aug 18, 2012 9:57 AM   in reply to arjun2
    You can also do it interactively with the Smart Guides turned on.
    On the image below, the group on the right side is scaled up so that the pentagon in the group is the same height as the star
    image 1) With all objects in the group selected, pick Direct Selection Tool (white pointer), click on the lowest point of the pentagon, and drag down until the Smart Guides show a line indicating it's aligned with the lowest point of the star.
    image 2) Pick the Scale Tool, first click on the point marked with the red arrow to set the center of scale, then click and drag the highest point of the pentagon following the Smart Guides' line showing uniform scaling until the alignment line with the highest point of the star appears
