Hello,
I just discovered that when I enable a course in Captivate 6 to report as SCORM 2004, that my option to choose to report the quiz score to my LMS as a percentage or as a score is taken away from me. I still have the option if I choose SCORM 1.2, but I'd prefer to use SCORM 2004 over 1.2.
See the screen shots below. The top image is from a Mac (that shouldn't make a diference, right?) but when I change it to SCORM 1.2, the Quiz Score option appears. The bottom image is from a PC.
Is there a workaround for this? Or a patch? Or plan to fix this in a later release?
Unfortunately they removed this feature in Captivate 6 per design in order to adhere to SCORM specs.
I highligted this problem as well earlier, but apparently the SCORM 2004 spec states that both cmi.score.raw and cmi.score.scaled should be supported by an SCORM 2004 compatible LMS. In Captivate 6 then using SCORM 2004 Captivate will send both cmi.score.raw and cmi.score.scaled and it's then up to the LMS to choose which one to use.
Unfortunately SCORM specs are read, interpretated and implemented in many different ways by different LMS vendors so it's not certain that your particular LMS support this.
The LMS that we use in my company does not support it so we can't use SCORM reporting from Captivate 6 at all.
www.cpguru.com - Adobe Captivate Widgets, Tutorials, Tips and Tricks and much more..
