NW1974
Fatal Error
Aug 15, 2012 3:04 AM
Hello
I seem to be having an error that has been present in Captivate for a while - looking at the discussions, I have not found anyone who actually solved the issue.
I installed Captivate 6 as a trial. I was able to run the software and make software simulation slideshows. However, today i cannot! I am not sure what has happened. I get the attached error when I run the application As Administrator, and try to start making a software simulation.
I have uninstalled Captivate, rebooted, installed, failed, uninstalled, deleted the program file folders, deleted the preferences in the app folder etc. Nothing seems to work.
Is there something extra I need to do in order to wipe this application completely, and just get up and running again? I am lucky that at the moment I am trialling this software - but it seems to be giving issues within 2 days of using it.....
    Aug 16, 2012 10:20 AM   in reply to NW1974
    Any chance that you are on a corporate network? If so make sure that your Captivate Project Cache folder is not located on a network location. Note that "My Documents" may very well be a network location (roaming profile) so try and create a directory on your C:\ drive where you keep the cache files.
    Cache files on a network location can easily cause this fatal error (it did for me)..
    www.cpguru.com - Adobe Captivate Widgets, Tutorials, Tips and Tricks and much more..
Bookmarked By (1)
