Is there any way to sequence non-threaded text frames? I want the text to appear in order in SDL (translation software).
Thanks all. RR
The best way I know to do this in large scale is using this free plugin: http://www.rorohiko.com/wordpress/indesign-downloads/textstitch/
Maria
Last time I checked, the Articles tool only affected reading order in PDF. I know of no translation tools that consistently do a good job harvesting text from PDFs, and SDL's tools only accept IDML. TextStitch is useful because you can just let it auto-stitch the whole document if all frames should be read in a top-down, left-right order.
However, StoryCollector and other SDL tools also collect frames in that order. So, using the QuickStitch function of TextStitch, you can rapidly thread all the frames in a document. Note that you will want to ungroup any group that contains a text frame before you begin - TextStitch gives you visual feedback, "blackening" frames that are going to be included in the threaded story, but it doesn't black out threaded frames in groups, so if you want to be able to see what you are doing, then you'll have to ungroup.
EPUB too? That makes sense. I should break down and make some EPUBs - I taught myself CSS for that exact reason, time to put it to use!
I have to say that I've never seen a translation tool do a consistently good job on PDFs
because some of them do support PDF as an input format. And, FWIW, I assume that one of these days the Articles tool will let us sequence frames for automated translation of IDML files - I've stared at the raw IDML for long enough to know that the sequencing information is there, but the translation tools I've used or demoed have not yet been updated to use that information. Hope springs eternal...
