joh87
Pop-up blockers and redirect in a new tab
Aug 16, 2012 10:43 AM
Tags: #actionscript #actionscript3 #redirect
I want a .txt page to be opened in a new tab when the .swf file opened. IE blocks it.
The .swf will be called from an external web page. Therefore, I cannot add more code there.
I'm not much experienced  with AS and tried adding different codes in the timeline. navigateToURL with "parent" works to open in the same page but can't get it to open in new tab, with "_blank".
    Aug 16, 2012 11:08 AM   in reply to joh87
    This target="" attribute on an anchor is depreciated. It is invalid markup. The reason why is it is decidedly the "users" decision to open content in a new window or a new tab, no longer yours. You can open child windows via javascript which are then owned by the parent window and allowed (aside popup blockers).
    The only way I've found that validates and opens a new window, yet is probably going to be fixed, is intercepting an anchor link such as:
    <a href="http://www.adobe.com" onclick="target='_blank';">Open adobe in a new tab or window (based on browser preferences)</a>
    However you said you do not have access to the code on the page the SWF lands on? If that's the case then you simply can't do what you want from inside a SWF alone. You can't make an anchor or write any custom JavaScript to work with ExternalInterface so you can't do it.
