Can i make Illustrator Package as InDesign?
Aug 16, 2012 8:05 AM
Hi guys,
Is there any way to make Illustrator Package images and fonts as InDesign? I check out a script in Internet but the link is broken. That would be great!
Btw, I would like for the future that the link palette in Illustrator would be more functional...double click on the image icon and open it directly in the Finder and not having to make an extra step to look for the menu and then Open in Bridge. What do you think?
Thanks for any info!
Cheers,
S.-
    Aug 16, 2012 8:57 AM   in reply to SebastiaoV
    depending on your version, but you might be able to do it in the future:
    http://blogs.adobe.com/creativecloud/sneak-peek-package-files-in-illus trator-cs-6/
    Aug 16, 2012 8:58 AM   in reply to SebastiaoV
    No. Illustrator does not provide a "collect for output" command. Nowadays, one usually delivers whole document designs for printing as press-ready PDFs. Because PDFs embed images and fonts, it's usually actually a better workflow (even for InDesign).
    JET
    Aug 16, 2012 9:18 AM   in reply to Monika Gause
    Illustrator is at version 16 and has been sold since 1987. That feature has not been added in all those updates over more than a quarter of a century.
    Yeah, think on that.
    Aug 16, 2012 12:12 PM   in reply to SebastiaoV
    Or you could use another application to package. Such as Markzware's Flightcheck:
    http://markzware.com/products/flightcheck/
    Aug 16, 2012 3:54 PM   in reply to JETalmage
    A perfectly valid use for a Package function is to transfer artwork along with its associated files & fonts to another computer.
    Aug 16, 2012 9:07 PM   in reply to SebastiaoV
    That point would only hold up, if the user did not save the pdf with the ai file embedded. Besides, if you save your files to a folder for each job, it wouldn't be very hard to zip that folder.
    Sep 23, 2012 6:54 PM   in reply to SebastiaoV
    here's one plugin for $25 to $30 depending on your version
    http://worker72a.com/
    Sep 24, 2012 3:05 PM   in reply to SebastiaoV
    Illustrator CS6 on Creative Cloud just had an update that adds the package function: awesome! (And about time.)
    Prior to that, I used Scoop, at the link for worker72a.com/ above. Works great.
    Sep 25, 2012 10:34 AM   in reply to SebastiaoV
    You also may want to look into Artfiles.
    Artfiles is a standalone app, so you can package multiple .ai files with one drag & drop. Makes fitting on a disk or ftp'ing quicker so you dont have duplicate hi res images/fonts as with scoop. Scoop does cost about $20 less.
    Feb 1, 2013 9:29 AM   in reply to SebastiaoV
    There is a sample script that comes with Illustrator which will allow you to package the files together just like InDesign. The only downside is it does not package the fonts that are used. All you have to do is transfer the "CollectForOutput" script that is located in the Sample Scripts folder into the Scripts folder. The link below provides step by step instructions.
    http://jokographic.com/?p=270
    Feb 1, 2013 12:40 PM   in reply to pereiraf
    One way to collect all of the fonts used in an illustrator file is Select> Object> Text objects, Edit-copy. Open a new InDesign file and paste, then Package for output the Indesign file for the fonts only.
