How do I remove just the TOC, or Just the Index, or both? I only want the Search tab to display.
Aug 16, 2012 1:29 PM
Tags: #robohelp_8
We use the TCS suite to create multiple webhelp projects.  We're integrating a virtual assistant with our help, and I've been asked to remove the TOC tab from displaying.  The index, glossary, and search can remain.
I don't know how to accomplish this. I'm sort of a newbie.
And if there is a way to remove the TOC tab, is it an all or nothing deal? Can I remove it from appearing in some parts of the webhelp output but not all of them?
Thank you all for your help!
  • RoboColum(n)
    Oct 8, 2004
    Aug 16, 2012 2:00 PM   in reply to RunForrestRun
    Yes you can do this. It is all controlled from the window you are using in your project. First the window must have been created when WebHelp was your default Single Source Layout. If it isn't, right click on WebHelp in the Single Source Layout pod and select the Set as Primary Layout option. To create a window, open the Project Set-up pod, right click on the Windows folder and select New Window. If you already have a window, double click on it to display its properties. On the right hand side you'll see a series of tick boxes in the Buttons section. You just need to deselect the Contents tick box. Note that this is the default button be default so deleting it will mean you'll want to assign one of the others as the default. To do that, select the button and click the Set as Default button.
    Aug 16, 2012 2:55 PM   in reply to RunForrestRun
    Hi there
    I hate to disagree, but I think Colum is leading you down a dark alley.
    Unless I'm horribly mistaken, you accomplish this by adjusting a setting in your Single Source Layout recipe. I know you said you are using TCS, but you didn't say which version. So I'm going to assume version 9 here.
    From the Single Source Layouts pod, double-click the WebHelp layout. Then click the Navigation section and clear the TOC check box to remove the TOC and the TOC button in the skin.
    Click the image below for larger and clearer view.
    Once you have done this, generate your WebHelp again.
    Cheers... Rick
    Helpful and Handy Links
    RoboHelp Wish Form/Bug Reporting Form
    Begin learning RoboHelp HTML 7, 8 or 9 within the day!
    Adobe Certified RoboHelp HTML Training
    SorcerStone Blog
    RoboHelp eBooks
  • RoboColum(n)
    Oct 8, 2004
    Aug 17, 2012 2:24 AM   in reply to Captiv8r
    Sorry for misleading you. Thanks for correcting me RIck. I am of course a WebHelp Pro person which works as I described. I must stop looking at these forums late at night when my brain is even more frazzled than normal
