Footer is not appearing?
Aug 16, 2012 12:43 PM
Can anyone help me figure out why the footer is not appearing on this page: http://wakinguptogether.org/index_test6.html
I'm using the footer CSS from one of the Dreamweaver supplied pages and I'm a beginner with CSS.  I'm at my wits end.  This is happening on another site i'm working on as well.  Thanks in advance for any help!
    Aug 16, 2012 1:10 PM   in reply to 1111lauer
    Change:
    }</script>
    </script>
    </script>
    <p></p><script type="text/javascript">
    <div class="footer">
    <p>Copyright 2012, Elizabeth Rabia Robert &amp; The Boulder Institute</p>
    <!-- end .footer --> </div>
    <!-- end .container --> </div>
    to:
    }</script>
    That should sort the footer issue. However, you may want to validate your page as you have styles and scripts all over the place.
    http://validator.w3.org/
    Aug 16, 2012 2:20 PM   in reply to 1111lauer
    Try this: http://pastebin.com/jxY49vkb
    What I did:
    • There was a </div> missing after the sidebar div so this was added in.
    • I then moved the footer below the content and sidebar but inside the container.
    • I gave the footer div a 100% width and float:left.
    • I added overflow:auto to the container to contain the floats.
    • I cleaned up the code to remove all your errors so it should now be error free.
    Rik
    Aug 16, 2012 5:43 PM   in reply to 1111lauer
    1111lauer wrote:
    I feel pretty sheepish asking, but I have the exact same problem on this page, on a different site: http://www.skytribe.com/contact.html, the footer doesn't display.
    which browser are you using to view your pages?  I tested your site in FF and IE9 and I can see the footer all right but not at the correct place.  Click on this image to see it framed in red color:
    Good luck.
    Aug 17, 2012 8:47 AM   in reply to 1111lauer
    That's the problem with having your styles embedded on each page rather on one single CSS file - things change per page and you lose track. Combine all your styles into one CSS file and link each page to the same sheet. This will keep things consistent.
    /* ~~ The footer ~~ */
    .footer {
    position: absolute;
    background-image: url(images/Footer2.jpg);
    background-repeat: no-repeat;
    height: 75px;
    padding-top: 10px;
    padding-right: 0;
    padding-bottom: 10px;
    padding-left: 0px;
    text-align: center;
    width: 100%;
    float: left;
    clear: right;
    font-style: normal;
    www.skytribe.com/video.html
    .footer {
    position: relative;/* this gives IE6 hasLayout to properly clear */
    clear: both; /* this clear property forces the .container to understand where the columns end and contain them */
    background-color: #000000;
    background-image: url(images/Footer3.jpg);
    height: 64px;
    padding-top: 15px;
    padding-right: 0;
    padding-left: 0;
    text-align: center;
    Aug 17, 2012 10:44 AM   in reply to 1111lauer
    Add the closing bracket to one of your CSS rules - it appears that the styles below this one are not being used due to a missing closing bracket.
    .content ul, .content ol {
              padding: 0 15px 15px 40px;
    } /* Add this closing bracket in */
