pmlink360
CFspreadsheet issue
Aug 11, 2012 3:33 PM
Hello, I have a question about CFspreadsheet....
I'm reading a spreadsheet and inserting the data into  a SQL server  DB....everything works fine unless 1 of my columns in the spreadsheet is blank. I'm getting the following error:
Element PHONE is undefined in EXCELQUERYBYNAME.
I tried the put a cfif isdefined to see if that would solve it but no luck....same error message. How can I handle this issue? My cfquery is below:
<cfquery name="insert_Sh_data" datasource="#datasource#">
    INSERT into contactrecord
       contact_date,
       fname,
       lname,
       address,
       city,
       state,
       zip,
       county,
       <cfif isDefined(excelQueryByName.phone)>phone,</cfif>
       <cfif isDefined(excelQueryByName.cell)>cell,</cfif>
       <cfif isDefined(excelQueryByName.fax)>fax,</cfif>
       <cfif isDefined(excelQueryByName.title)>title,</cfif>
       <cfif isDefined(excelQueryByName.organization)>organization,</cfif>
       <cfif isDefined(excelQueryByName.email)>email,</cfif>
       <cfif isDefined(excelQueryByName.general_comments)>general_comments,</cfif>
       <cfif isDefined(excelQueryByName.fname2)>fname2,</cfif>
       <cfif isDefined(excelQueryByName.lname2)>lname2,</cfif>
        mailing,
        input_by,
        input_date,
        input_time,
        input_by_id,
        country,
        sh_rating
        Values(
        '#Trim(excelQueryByName.contact_date)#',
        '#Trim(excelQueryByName.fname)#',
        '#Trim(excelQueryByName.lname)#',
        '#Trim(excelQueryByName.address)#',
        'Trim(excelQueryByName.city)#',
        '#Trim(excelQueryByName.state)#',
        '#Trim(excelQueryByName.zip)#',
        '#Trim(excelQueryByName.county)#',
        <cfif isDefined(excelQueryByName.phone)>'#Trim(excelQueryByName.phone)#',</ cfif>
        <cfif isDefined(excelQueryByName.cell)>'#Trim(excelQueryByName.cell)#',</cf if>
         <cfif isDefined(excelQueryByName.fax)>'#Trim(excelQueryByName.fax)#',</cfif >
         <cfif isDefined(excelQueryByName.title)>'#Trim(excelQueryByName.title)#',</ cfif>
         <cfif isDefined(excelQueryByName.organization)>'#Trim(excelQueryByName.orga nization)#',</cfif>
         <cfif isDefined(excelQueryByName.email)>'#Trim(excelQueryByName.email)#',</ cfif>
         <cfif isDefined(excelQueryByName.general_comments)>'#Trim(excelQueryByName. general_comments)#',</cfif>
         <cfif isDefined(excelQueryByName.fname2)>'#Trim(excelQueryByName.fname2)#', </cfif>
         <cfif isDefined(excelQueryByName.lname2)>'#Trim(excelQueryByName.lname2)#', </cfif>
         '#Trim(excelQueryByName.mailing)#',
         '#Trim(excelQueryByName.input_by)#',
         '#Trim(excelQueryByName.input_date)#',
         '#Trim(excelQueryByName.input_time)#',
         '#Trim(excelQueryByName.input_by_id)#',
         '#Trim(excelQueryByName.country)#',
         '#Trim(excelQueryByName.sh_rating)#'
</cfquery>
Thanks in Advance.
    Aug 11, 2012 3:54 PM   in reply to pmlink360
    Instead of checking to see if the field is defined, check to see if the length is greater than 0.
    Aug 13, 2012 12:06 AM   in reply to pmlink360
    The error "Element PHONE is undefined in EXCELQUERYBYNAME." indicates that the 'phone' column doesn't exist in the query object. Which I guess means the phone column doesn't exist in the Excel spreadsheet.
    What do you see when you dump EXCELQUERYBYNAME? Can you see the phone column?
    In theory you could use:
    <cfif StructKeyExists(EXCELQUERYBYNAME, "phone")>phone,</cfif>
    Even if the object isn't actually a Struct.
    Aug 16, 2012 2:55 PM   in reply to pmlink360
    You need to put your parameter in quotes when using isDefined, like so:
    cfif isDefined("excelQueryByName.phone")>phone,</cfif>
