va7rmm
Large .eps file to .pdf problem
Aug 10, 2012 4:11 PM
Tags: #pdf #large #eps #convert
Some ten or more years ago I published a book of family history, and saved the .eps file. That file was approximately 9.2 mbytes. Now I would like to convert it back to a pdf file, but the converter, while working flawlessly, always stops at page 56 of the book - making a .pdf file of just over 2 Mbytes. the book contains over a 100 pages. I am using the distiller in Adobe Acrobat 6. I suspect a file size problem, but am only guessing.
Can anyone help me to obtain a complete conversion of the .eps file?
    Aug 11, 2012 4:02 AM   in reply to va7rmm
    If you aren't using Distiller SERVER, you've posted in the wrong place - and the problem is that almost nobody has the Distiller Server product so nobody may be able to see your message and help. Please try the Acrobat Creating Editing & Exporting PDF forum. You will probably have to do more explanations since an EPS is strictly and always a format of exactly one page. Good luck!
    Aug 16, 2012 3:53 PM   in reply to va7rmm
    Moved to Creating, Editing & Exporting PDFs.
    It sounds like page 56 is corrupt.
    Aug 17, 2012 4:03 AM   in reply to Test Screen Name
    You mention converter, but that does not tell us what you did. Please explain what packages you are using and the steps you are taking. Also, what version of AA6 are you using. The latest is Version 6.0.6.
