rodneyfleming
Hidden fields in Adobe using Java
Aug 16, 2012 5:36 PM
Tags: #acrobat #pdf #script #javascript #scripting #acrobat_x_pro
Hello,
I am trying to write a script that will hide a certain field based off the value inserted in another field.
I have started with this:
   var show = true;
   if(this.getField("quantity1").value.length == 0)   show = false;
   if(show)   this.getField("linetotal1").value = display.visible;
   else   this.getField("linetotal1").display = display.hidden;
   event.value = this.getField("quantity1").value * this.getField("unitprice1").value;
Now, when there is no value inserted in "quantity1", then the correct field "linetotal1" is hidden.  The problem I am having is the field is staying hidden if I go back and put a value in "quantity1".
Is there a way to have a loop or another if statement to correct this problem? Or is there a better way to do this action all together?
Thanks in advance,
Rod
  • George Johnson
    Aug 11, 2002
    Aug 16, 2012 9:05 PM   in reply to rodneyfleming
    Simplifying a bit, try this:
    // Show/hide linetotal1
    getField("linetotal1").display = getField("quantity1").valueAsString ? display.visible : display.hidden;
    // Calculate this field's value
    event.value = getField("quantity1").value * getField("unitprice1").value;
