PS don't "check-in" on my mac
Aug 17, 2012 2:35 AM
Tags: #photoshop #bridge #cq5.5 #adobedrive
I'm using CQ5.5 DAM, and PS6 Extended.
For any reason, on a Mac running Lion, I can't check in files opened with Bridge and stored in CQ-DAM mounted with Adobe Drive 4...
It works well with Illustrator, but for Photoshop I have to manually Check-out/in files in Bridge.
On a PC it works...Is it only a Mac issue ?
    Aug 17, 2012 5:54 AM   in reply to jmlg12
    I've forwarded your question to the Adobe Drive forum.
    Aug 19, 2012 7:57 PM   in reply to jmlg12
    The behavior is not expected, we have done many testing work for PS with Adobe Drive 4 on Mac 10.7.
    To figure out what happened on your machine, could you help do the following steps?
    1) Summarize the OS version and PS build you installed
    2) Attach the ServiceManager log under /<username>/Library/Application Support/Adobe/AD4ServiceManager/logs
    3) open a shell terminal, and export AdobeDriveLogLevel=DEBUG, then launch PS using the command line: /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/MacOS/Adobe Photoshop CS6, then attach the log unser  /<username>/Library/Application Support/Adobe/Adobe Drive 4/logs
    Aug 20, 2012 2:21 AM   in reply to jmlg12
    Ok, I mean , please collect the log files just mentioned and post them here, thanks
    Meanwhile, from the system information, you are running PS on a non-English platform, what's the system language?
    Aug 20, 2012 3:05 AM   in reply to jmlg12
    Ok, I think it is unnecessary to run Lion in French.
    Could you please collect the log files just I mentioned, zip them and post here?
    Meanwhile, in PS, what file status did you get? "unmanaged files", "new file" or "checked-out by me"?
    I think this problem has nothing to do with running the CQ 5.5 instance locally, it's not a problem
    Aug 20, 2012 7:11 PM   in reply to jmlg12
    ok, please send the zip file to me by mail to this addrees (gzheng@adobe.com).
    Meanwhile, could you help re-try the scenario on you machine, this time, please open /Application/Utilities/Console.app before you are ready to check in files in PS, after check-in menu is clicked,  make sure "All Messages" in the left pane in Console is selected, and choose File/Save a Copy As from the main menu of Console application, please also send me this copy file to me by mail
    Gang
