Flash Builder 4.6 crashes on startup
Jun 13, 2012 3:31 AM
Tags: #problem #error #workspace #4.6 #adobe_flash_builder_4.6
  Latest reply: Tronster_, Mar 11, 2013 7:51 PM
Replies 1 2 Previous Next
    Jul 29, 2012 2:59 AM   in reply to mugdha choudhary
    The answer of mugdha worked for me too!
    Thank you very much!
    Jul 30, 2012 7:46 AM   in reply to mugdha choudhary
    This fixed it for me. This is the second time I have had activation issues. The first was with Acrobat X Pro. Will I have to go through this every 30 days?
    --rayne
    Aug 17, 2012 6:31 AM   in reply to lawrencem49
    this trick worked for me:
    So, if Flash Builder freezes trying to load your workspace what you need to do to fix it is to navigate to.metadata/.plugins/org.eclipse.core.resources and delete the file named .snap. That’s it. No more rearranging views and reimporting projects!
    Update: Looks like in workspaces created by Flash Builder 4.5 this file doesn’t exist. If I ever break a FB 4.5 workspace I’ll have to start looking for a solution all over again )8
    (taken from Valentin Simonov's blog http://va.lent.in/blog/2010/07/12/how-to-fix-flash-builder-broken-work space/)
    Sep 10, 2012 11:18 PM   in reply to mugdha choudhary
    Thank you!!!!!!!!!!!
    Sep 22, 2012 8:51 PM   in reply to mugdha choudhary
    I have no idea why this needs to be done in order for my program to work properly, but this did get it going.
    Followed mugdha's instructions a little less strictly and got Flash Builder 4.6 to start up.
    1) Opened Encore > Deactivated
    2) Closed Encore.
    3) Opened Encore > Entered my CS6 serial and signed in.
    4) Closed Encore.
    5) Opened Flash Builder 4.6 with success.
    Thank you.
    ~J
    Calculating status...
    Oct 9, 2012 11:34 AM   in reply to J4KEHiLL
    Thank you SO MUCH for this help.  My copy of Flash Builder 4.6 broke for me yesterday and nothing I tried worked.  As a last resort I tried once more and found your post and your solution worked!
    Nov 5, 2012 1:33 PM   in reply to maiatoo
    I still have this problem - tried all the deactivation and reinstall stuff. Can anyone help, please?
    Nov 28, 2012 8:08 PM   in reply to Hllmn
    Same here, I have tried every single method mentioned here wasting a good half of the day.
    Could some one please help us?
    Dec 4, 2012 12:46 PM   in reply to mugdha choudhary
    Nice Mugdha, that worked for me.
    Just followed your steps and started working again.  So far so good.
    thank you.
    Mac OSX 10.7.5
    Java Runtime 1.6
    CS6 Master Collection
    Jan 30, 2013 2:51 PM   in reply to chiwaili
    I don't know if anyone is still using Flash...haha , but another way to do it is to:
    Uninstall FB - check unstall preferences.
    Go to your original install dmz and start the install process.
    When the install shows you your serial number with the last four XXXX, reinter your whole serial number.
         (I tried installing without entering in all the serial number and relying on it remembering, but it didn't change the problem outlined in this thread.
         You will be prompted to sign in
    Select FB ( I happened to have Dreamweaver checked also, so it was installed also...you may want to select some other compontent that is not installed)
    Install
    Since Dreamweaver installed along with it, I decided to open it first.  Don't know if that made any difference, but I wanted to show every step that I did.
    FB opened fine after that.
    I hope this helps someone.
    Mar 11, 2013 7:51 PM   in reply to AlanE_0604
    Same issue with Flash Builder 4.7, running OS X 10.7.5.
    I also have installed CS5.5 which includes Flash Builder 4.5
    Just started immediately crashing on launch yesterday.
    De-activate, reactivate CS5.5 did nothing and regardless, I don't consider reinstalling / reactivating software a "fix".  More like a klugy workaround at best.
    What's the official word on this...
    It's been about a year since this has been reported; is anyone actively looking into a real fix (e.g., determining why the software is doing this.)?
1 2 Previous Next
Actions
Bookmarked By (1)
