unegomme
Text color over transparent graphics and in on-screen display of PDFs 'printed' from InDesign
Aug 16, 2012 6:17 PM
Tags: #pdf #transparency #type_color
Hello, All!
I'm new here and am having trouble with color in InDesign CS3.  The attached collage of screenshots explains both parts of the problem:  putting a graphic under type prevents me from having the purple type I want—and, when I make a PDF from that InDesign document, all the right purple (even the stuff with no graphics beneath it) is converted to the wrong purple.  (Ignore the statement about zoom factors; it was explanation for a friend.)  It seems almost incredible that there's no way to avoid this problem, but my searches for the solution have been fruitless so far.  (I'm admittedly a novice in some aspects of InDesign.)
Although I may eventually print the document on actual paper, with just an inkjet printer, I'm not quite as concerned about the color there.  Just having the proper purple in the on-screen display of a PDF would be quite an improvement over the present roadblock.
Thanks to anyone who can help:  you surely know more than I about such things.
  • Rob Day
    Oct 16, 2007
    Aug 17, 2012 6:11 AM   in reply to unegomme
    If your document's destination is not an offset press set your Transparency Blend Space to RGB. The purple you are specing is not in the CMYK color gamut.
  • Rob Day
    Oct 16, 2007
    Aug 17, 2012 7:21 AM   in reply to unegomme
    Just to note, an RGB Transparency Blend space is not usually appropriate for a press workflow—your out-of-gamut purple will eventually be brought into gamut on press no matter what blend space is used. Also any black text will output as 4-color, which is often a problem on press.
    Aug 17, 2012 8:57 AM   in reply to unegomme
    On press spot colors are fine (they converted to CMYK on digital printers), but to use one you need to define a color as spot -- usually best to pick a swatch from one of the standard spot color libraries -- and then apply it to the text in question. If you don't tell ID that soomthing is a spot color there is now way the program is going to read your mind.
  • Rob Day
    Oct 16, 2007
    Aug 17, 2012 9:06 AM   in reply to unegomme
    but never could escape that muddy purple until I followed your suggestion about the Transparency Blend Space.
    A spot color will not be previewed inside the CMYK gamut when the blend space is CMYK if it's defined as Lab and Overprint or Separation Preview is turned on. In CS6 Pantone Solid Spot colors are automatically defined as lab. In earlier versions you may have to turn on Use Lab... in Ink Manager.
    Here my blend space is CMYK:
    Overprint off:
  • Rob Day
    Oct 16, 2007
    Aug 17, 2012 9:25 AM   in reply to unegomme
    2.  Second part (on-screen display of the PDF):  When making the PDF from InDesign's "Print" dialog box, go to the "Output" 'tab' and, under "Color", choose "Composite RGB".
    The PDF/X-4 preset lets you export a spot color document unchange—you won't loose the spot and CMYK values and it will preview without clipping:
