swigglerz
match frame in multi clips
Aug 8, 2012 1:16 PM
Tags: #frame #pro #premiere #cs6 #match #multiclip
hey there,
just finished a multiclip sequence in PP CS6 so next on my list would be going from the multiclip to an "online" timeline, meaning:
- matchframe each clip and paste the original above the multiclip-bits so i can export a nice .xml to proceed to color correction.
but each time i try to match back to the original frame PP just puts me back on the angle in my multiclip i had selected earlier.
any idea what i am doing wrong?
thanks in advance.
    Aug 8, 2012 3:31 PM   in reply to swigglerz
    What's a multiclip?  Do you mean multicam, with several different camera angles?
    Aug 9, 2012 6:32 PM   in reply to swigglerz
    I get it.
    CTRL+SHIFT+F to get to the same frame in the original sequence, then F again to load that clip into the Source Monitor.  (Be sure only the proper track is targeted.)
    Aug 16, 2012 4:56 PM   in reply to swigglerz
    Now I'm confused again.
    What do you mean "it just matches the frame, not the clip (including in/out)"
    When you hit F in the original sequence, it brings up that clip in the Source Monitor, with In/Outs marked and the CTI on that same frame.
    Aug 17, 2012 8:52 AM   in reply to swigglerz
    so if there's any shorter way
    Nope.  That's pretty much the only way.
    Aug 17, 2012 11:48 AM   in reply to swigglerz
    I've never needed to do this myself, but feature requests can be made below:
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    Aug 17, 2012 12:15 PM   in reply to swigglerz
    In FCP it should only take a few seconds because you just select, right-click, and choose "collapse multiclips."  Beauty is that its just as easy to un-collapse if you need to re-edit.
    If Premiere delt with multi-cam better I could un-install that antique software completely....
    Feb 8, 2013 11:40 AM   in reply to swigglerz
    I'm also writing a feature request for this, but in the meantime, your process isn't working for me.
    Ctrl-Shift-F does nothing.  Neither does Cmd-Shift-F.
    In the nested sequence, when I hit F, it opens the frame in the multicam sequence in the source viewer.  Hitting F again does nothing.  So how do I get to the original clip?  I'm using Premiere 6.0.2 on a mac.
