My website it not going directly to index.html
Aug 17, 2012 10:13 AM
When i pull up my domain name its not going to index.html its going to a file directory with all the file name i know i am uploading it right what is going on?
http://creationsmh.com/
you have to type in
http://creationsmh.com/Index.html
to make it work correctly how do i make index.html the landing page?
    Aug 17, 2012 10:21 AM   in reply to super waffle
    Note that you have named your file "Index.html" and you probably should be using "index.html".  Things on the web are usually CaSeSensitive!
    Aug 17, 2012 10:22 AM   in reply to super waffle
    Some ISP servers require the 'frontpage' to be named homepage.html - this may be the case with yours but I would go to your ISP's FAQ page and try and find out what is required. It's unusual that a server would not be set up to find index.html, index.htm, homepage.html or homepage.htm but I guess there may still be some out there.
    Aug 17, 2012 10:23 AM   in reply to MurraySummers
    Good spot Murray......not using lower case 'i' could mess things up.
