Adding Doc Type for Color Coding
Jul 1, 2012 4:35 AM
Tags: #color #cs6 #color-coding
I'm using DW to modify my .LUA files, and I'd love to create the rules for Code Coloring.
Is there a way to add a new Document Type for this purpose?
I'm using CS6 now.
    Jul 2, 2012 3:11 AM   in reply to steeletech
    Deatils on how to add new document types to Dreamweaver are here: http://helpx.adobe.com/dreamweaver/kb/change-add-recognized-file-exten sions.html.
    There's also an old article on extensible colour coding here: http://www.adobe.com/support/dreamweaver/extend/extensible_code_colori ng/
    I'm not sure if significant changes have been made to colour coding since that article was written. Maybe you could try it and report back here. If it's out of date, I'll contact the engineering team to see if more up-to-date material is available.
    Jul 3, 2012 4:15 AM   in reply to steeletech
    I don't think that adding new file types will allow you to add them to the New Document dialog box, but I've asked someone from Adobe to take a look at this thread. I suspect that the documents are out of date and need to be revised.
    Jul 4, 2012 4:03 AM   in reply to steeletech
    I've been in touch with the engineering team, and they've promised to get the documents updated. They might even contact you directly.
    Aug 17, 2012 6:09 AM   in reply to steeletech
    Hello,
    Extremely sorry for the outdated contents in the above mentioned documents.
    I have logged a backlog to update the documents and also a feature request. We will surely address the same.
    Yalpi Shiva Prasad
    Adobe Dreamweaver Team
    Oct 24, 2012 7:58 AM   in reply to Yalpi Shiva Prasad
    Hi, I'm using Dreamweaver CS6 Creative Cloud and I'm trying to add the extension EJS and SCSS. I've followed this walkthrough; http://helpx.adobe.com/dreamweaver/kb/change-add-recognized-file-exten sions.html. Adding it to HTML and Stylesheet groups within the extentions.txt and added it to the appropriate <documenttype> within the MMDocumentTypes.xml.
    Still getting the "Can't find a valid editor for this file extension".
    thx
    Oct 24, 2012 11:04 AM   in reply to iLoyola7
    In Dreamweaver Preferences (Edit menu on Windows, Dreamweaver menu on a Mac), select File Types / Editors.
    Add the filename extensions to the space-separated list in the "Open in code view" field..
    Oct 24, 2012 11:25 AM   in reply to David_Powers
    Thank you David for the responce, yes I have them added to the "open in code view" now and the files are opening in code view but I would also like design view, color coding, and server behavior functionality which is determined in the MMDocumentTypes.xml but not working. This is what I've put for the EJS;
    <documenttype id="HTML" internaltype="HTML" winfileextension="html,htm,shtml,shtm,stm,tpl,lasso,xhtml,ejs" macfileextension="html,htm,shtml,shtm,tpl,lasso,xhtml,ssi,ejs" file="Default.html" writebyteordermark="false" mimetype="text/html">
    <TITLE>
    <MMString:loadString id="mmdocumenttypes_0" />
    </TITLE>
    <description>
    <MMString:loadString id="mmdocumenttypes_1" />
    </description>
    <dtdcontext>html</dtdcontext>
    </documenttype>
    Feb 6, 2013 12:27 PM   in reply to Yalpi Shiva Prasad
    Is there any update on this? I have updated my  Extensions.txt file and
    MMDocumentTypes.xml to add the new file types but still can't see the color coding when I open documents of those file types.
    I am using Dreamweaver cs6 on a mac running snow leopard. I did not have any issues when i did this on cs 5.5.
