gobolemur
how do i embed audio (mp3) in muse?
Aug 16, 2012 9:17 PM
Tags: #help #audio #html #links #muse #support #embedding_audio
that was it...how do i embed audio (mp3) in muse? thank you.
    Aug 16, 2012 11:13 PM   in reply to gobolemur
    I uploaded a short screencast to YouTube on how to do it using soundcloud.
    How that helps!
    http://youtu.be/dBdSAzK0uSY?hd=1
    Aug 17, 2012 10:43 AM   in reply to MinimalGlen
    Object -> Insert HTML...
    and here is the code you need to paste into Muse:
    <embed src="sound.mp3" autostart="true" loop="false" hidden="true"></embed>
    Hope this helps!
    Julia
    Sep 5, 2012 10:38 AM   in reply to jgrummel
    Jgrummel, I tried pasting in your code with the name of an audio file, but it did not work even when I published. My guess is that the file needs to ALREADY be on the server, but then I thought if that was the case, does the embed code have to have a folder reference? I am not a coder, so I am trying to figure out at random. Can you provide any step-by-step process for getting audio files to play in the background WITHOUT the player being seen or being loaded in another page? Is the only option to use a thrid party server, like youtube, BUT with that issue is that I get suck with player controls that I do not wnat and it does not loop.
    Sep 5, 2012 3:58 PM   in reply to KazapCorp
    yes. you need to put the .mp3 file on the server and reference the src="" that way. for instanace, if you have it in a music folder on the server "music/music.mp3"
    Sep 11, 2012 1:17 PM   in reply to jgrummel
    it works, Hurra!
    Sep 12, 2012 9:45 AM   in reply to jgrummel
    Well it works, but!
    Is it possible to add background music to a web site, in muse?
    Site wide, with a start/stop button
    I tried the suggested code on a master page, it plays all right, but the music starts again every time you change page.
    (<embed src="my.mp3" autostart="true" loop="false" hidden="true"></embed>)
    Can you suggest an alternative option?
    Thank you
    Nov 22, 2012 1:52 AM   in reply to Santos49
    I'm having the same issue of the music restarting each time loading a new page, even when put into the MASTER for all the pages.
    Nov 22, 2012 3:16 AM   in reply to CynicSatirist
    As I understand it is not possible.
    Without more than elementary knowledge of html, css, and javascript, every page is another page, and de music starts again.
    Depending on the complexity of your project, you may perhaps resolve this problem quite easy using Edge.
    Feb 4, 2013 10:22 AM   in reply to jgrummel
    Hi... the audio is also very important to me. I embedded the code in the editor as you said. It worked.
    However, I am unfamiliar with how to get the audio player controls onto the screen so the user has control of starting, stopping, replay, volume, etc.
    Is there a way to embedding the audio along with a player?
    PS... this support site is fantastic for me.
