Fi_TW
Auto colour change?
Aug 17, 2012 3:24 AM
Tags: #auto #change #colour #form #100% #total #calculated
I would like to know how to make a calculated total automatically change colour when it hits 100%
    Aug 17, 2012 3:42 AM   in reply to Fi_TW
    Hi
    You should describe your question. What is 100% here? And color for what? TextField Color or Border Color, onfocus color what?
    Manjeet
    Aug 17, 2012 4:26 AM   in reply to Fi_TW
    You want to change the text(textfield values). You have designed your form in LiveCycle Designer. Right.
    So, go to the last TextField and select it. Then go to the script section chose calculate event and also chose FormCalc as scripting language not the javascript. Write the below code
    if (this.rawValue ==100) then
    TextField1.ui.textEdit.border.fill.color.value = "86,155,189";
    endif
    Manjeet
  • George Johnson
    Aug 11, 2002
    Aug 17, 2012 10:39 AM   in reply to Fi_TW
    You do not need to use LiveCycle Designer. You can do something like the following as the custom Calculate script:
    (function () {
        // Add up all of the field values
        var sum = +getField("text1").value;
        sum += +getField("text2").value;
        sum += +getField("text3").value;
        sum += +getField("text4").value;
        sum += +getField("text5").value;
        sum += +getField("text6").value;
        sum += +getField("text7").value;
        sum += +getField("text8").value;
        // Set this field value
        event.value = sum;
        // Set this field's text color
        event.target.textColor = sum == 100 ? color.red : color.black;
    Change the field names and colors to suit your needs. You probably want to explicitly round the sum to avoid things like: 0.2 + 0.1 = 0.30000000000000004, which will throw off the check for equivalence to 100 if non-integers are used for the inputs.
    Edit: corrected typo
  • George Johnson
    Aug 11, 2002
    Aug 17, 2012 10:58 AM   in reply to Fi_TW
    It is intended to be the custom calculate script for the field. I did have to correct a typo after my initial post, so try again. You can remove the comments if you like. They are the lines that begin with //.
