Premiere Elements won't install. InstallShield Wizard stops with a screen of parameter options and when I press OK it disappears. WinXP system with plenty of resources. Have redone download five times, including a direct download. Here is what installer screen has.
| Help information |
Restart Options
| /norestart | ||
| Do not restart after the installation is complete | ||
| /promptrestart | ||
| Prompts the user for restart if necessary | ||
| /forcerestart | ||
| Always restart the computer after installation |
Logging Options
| /l[i|w|e|a|r|u|c|m|o|p|v|x|+|!|*] <LogFile> | ||
| i - Status messages | ||
| w - Nonfatal warnings | ||
| e - All error messages | ||
| a - Start up of actions | ||
| r - Action-specific records | ||
| u - User requests | ||
| c - Initial UI parameters | ||
| m - Out-of-memory or fatal exit information | ||
| o - Out-of-disk-space messages | ||
| p - Terminal properties | ||
| v - Verbose output | ||
| x - Extra debugging information | ||
| + - Append to existing log file | ||
| ! - Flush each line to the log | ||
| * - Log all information, except for v and x options | ||
| /log <LogFile> | ||
| Equivalent of /l* <LogFile> |
Update Options
| /update <Update1.msp>[;Update2.msp] | ||
| Applies update(s) | ||
| /uninstall <PatchCodeGuid>[;Update2.msp] /package <Product.msi | ProductCode> | ||
| Remove update(s) for a product |
Repair Options
| /f[p|e|c|m|s|o|d|a|u|v] <Product.msi | ProductCode> | ||
| Repairs a product | ||
| p - only if file is missing | ||
| o - if file is missing or an older version is installed (default) | ||
| e - if file is missing or an equal or older version is installed | ||
| d - if file is missing or a different version is installed | ||
| c - if file is missing or checksum does not match the calculated value | ||
| a - forces all files to be reinstalled | ||
| u - all required user-specific registry entries (default) | ||
| m - all required computer-specific registry entries (default) | ||
| s - all existing shortcuts (default) | ||
| v - runs from source and recaches local package |
Setting Public Properties
| [PROPERTY=PropertyValue] |
Consult the Windows ® Installer SDK for additional documentation on the
command line syntax.
Copyright © Microsoft Corporation. All rights reserved.
Portions of this software are based in part on the work of the Independent JPEG Group.
That's just debug info for the MS installer. Completely useless. All that it indicates is that the installer did not run at all because either
a) Your system is not qualified or
b) Your installer infrastructure is completely FUBARd
Refer to the system requirements and then repair your MSI stuff by downloading teh package from Microsoft/ running Windows Update.
Mylenium
