Web App sorting question
Aug 17, 2012 8:07 AM
Hello,
Can a webapp be sorted by a custom field? I have a user input form that has a date field.  I need the date field they enter to sort from latetest to earliest.
If it can't be done, how can I make the release date show up right away? Thanks again, the BC Forum has been great so far.
    Aug 17, 2012 11:20 AM   in reply to elmo1999
    Not using a custom field however there sre some options per my screen cast.  You could use the "weighting field" to set custom sorting.
    Please view this article for more parameters for web apps.
    - http://kb.worldsecuresystems.com/134/bc_1345.html#main_Web_App_Modules
    Kind regards,
    -Sidney
    Dec 19, 2012 6:15 AM   in reply to Sidney Mitchell
    Hi Sidney,
    i need to sort by date, as I want to have a list of upcoming events (event module doesnt help here, because its not having a "venue"-field, why is that, every event has a location...)
    So weighting is no use, because after having created 50 events in a range of a year and another one has to be added, i would have to find the weighting of the event before the new one and then... gosh, thats much to complicated. Of course, your system has the ability to sort by date. Please tell me how?
    Regards
    Dec 19, 2012 9:12 AM   in reply to graugans Design
    The only other option is to either use the "date" or "datereverse" which will only display based on the release date and not the custom field "date needed" I'm afraid.
    Dec 19, 2012 9:18 AM   in reply to Sidney Mitchell
    Nope, Sidney,
    i found a solution in the forum: http://forums.adobe.com/docs/DOC-1853#comment-7001,
    use weightingreverse and the date in format 20121022.
    Regards, Dennis
    Dec 19, 2012 9:20 AM   in reply to graugans Design
    Humm..maybe I should have been clearer in my initial post..
    "You could use the "weighting field" to set custom sorting."
    That was meaning to use the "weightreverse" parameter since its the only option that control the weight custom sort.
    Glad you were able to locate a solution.
    Cheers!
    -Sidney
    Dec 19, 2012 9:21 AM   in reply to graugans Design
    Using the weighting field will work for you quite fine. I ran into this exact same issue.
    In the weighting field just use the event start date such as:
    20121219 for December 19, 2012
    Then no matter what your dates are or when you enter them they will always be in the proper order without having to find the before and after weighting.
    Dec 19, 2012 9:22 AM   in reply to graugans Design
    Ah, okay I see you found the solution as I was posting. Good luck!
    Dec 19, 2012 9:23 AM   in reply to Brad Lawryk
    As always thanks Brad.
