ALevkov
Need my recording settings changed back.
Aug 17, 2012 12:50 PM
I am using Captivate 5.  My recordings have always recorded each mouse click, and provided a text bubble.  The filmstrip on the left of the edit screen show the slide with a mouse icon just under the right corner.  Suddenly all of my recordings are being made with a different setting.  Now the filmstrip shows a movie camera icon without any mouse clicks or text bubbles.  How do I get back to what I had originally??
    Aug 17, 2012 1:18 PM   in reply to ALevkov
    Which recording option did you choose? Perhaps you changed to FMR instead of Automatic recording? The camera icon indicates that the recording was a Full Motion Recording.
    Lilybiri
    Aug 17, 2012 1:38 PM   in reply to ALevkov
    Strange: is this the case for all the slides? Do you see a red line in the center of the timeline bar for the slide? Can you close Captivate, restart and try again? Normally in Automatic mode Captivate switches to Full Motion Recording only for the situations listed in the Preferences, Recording, Settings: Drag&Drop and Mouse wheel actions. You can also force into FMR during capture by using the shortcut key F9 - did you do that perhaps?
    Lilybiri
    Aug 20, 2012 10:16 AM   in reply to ALevkov
    Did you retry? Clear the cache, eventually clear the Preferences folder, it is labeled Captivate 5 and can be found in your profile:
    On Win7 it is to be found in :\\Users\<your username>\Appdata\Local\Adobe\
    Beware: you will lose all customisation deleting this folder while CP is closed, when restarting a new folder will be created and you are back to default settings.
    Lilybiri
    Aug 21, 2012 8:05 AM   in reply to ALevkov
    Great! Could you mark the question as answered?
    Lilybiri
    Aug 27, 2012 8:30 AM   in reply to ALevkov
    I just ran into the same problem.  After recording several demos over the past few days, with no problem, many of my mouse clicks (and resulting screen shots) are no longer being recorded in automatic mode.
    I have been looking for the "preferences" file, so that I could delete it.  But, I can't seem to find one.  Is there a chance, if I haven't set any preferences, that I don't have one?
    I'm on Windows 7 and looked in subdirectories of:
        C:\Users\<MyName>\AppData\Local\Adobe\Captivate 5\
    Aug 27, 2012 8:51 AM   in reply to IdleChatter
    The Preferences "file" is actually a collection of files inside that Captivate 5 folder.  So just rename that entire Captivate 5 folder as CaptivateOLD.   When you next start Captivate it will create a new folder again with new default preferences.
    Aug 27, 2012 12:32 PM   in reply to ALevkov
    Thanks for the tips.  I cleared my cache, renamed the "Captivate 5" folder and even shut down and rebooted my system.  None of this seems to help.  I must have reset a parameter that I'm not catching.  When I do something as simple as (mouse clicking each one):
      Start All Programs Accessories System Tools System Information
    All I get in the resulting file is a frame with the click on "Start" and then the the next frame is the System Information window (none of the clicks in-between).
    With the System Information window up, I expand each of the left categories by clicking the "+" to the left, but all I see in my resulting Captivate project is the screen that results after all three have been expanded (not each individual expansion).
    Update:  This appears to be related to the fact that I'm trying to capture from a remote desktop.  After adjusting my settings, and trying a few other tests with a co-worker, I found that the lack of screen captures only happens on this remote desktop.  The odd thing is that I hear the Captivate-initiated mouse-click, so I know Captivate is aware of this activity.  It's just not saving all of these mouse click screens.
    Sep 26, 2012 4:05 AM   in reply to IdleChatter
    I am also facing the same problem did you get any solution on this? i am not capturing  from remote but even though when i am opening a popup within the application i am trying to capture this problem comes.
    if any one knows why is it happning Please let me know
    Sep 26, 2012 10:39 AM   in reply to ALevkov
    I've done a couple of things since my last note.  First, I always hit the "Print Screen" button if there's a screen I want to make sure doesn't get lost.  Second, I updated from Adobe Captivate 5.0 to 5.5.
    My method of hitting "Print Screen" so many times adds some edit time, since I frequently get the screen captured more than once.  But, as I mentioned in my note above, this was primarily happening when I used a Remote Desktop.
    Two other things...  First, with the Remote Desktop, even if a screen wasn't missing, sometimes Captivate would capture before the screen finished refreshing, which also made my manual captures more useable.  Second, I upgraded to Adobe Captivate 5.5 about half-way through this project (which consisted of about 40 short demos).  I seemed to have fewer problems with the updated software.  But, I kept performing the manual screen capture because it seemed easier to edit out the duplicate screens than to get an entire demo captured, only to find a screen was missing (or incomplete).
    Sep 26, 2012 10:11 PM   in reply to IdleChatter
    Thanks for the Reply but I am using captivate 5.5, and I followed all the steps mentioned, but no Luck!, hope reinstalling the software will help. however thanks for the reply. and update if you come to know better resulation for this.
    Sep 27, 2012 2:23 AM   in reply to Kusha.W
    Resoled by Pallavi from Adobe Helpline:
    goto Edit menu >> preference >> recording >> settings >> automatic user FMR for:
    uncheck Drag and Drop Action and Mouse Wheel Action
    thats it
