Acemon99
Keep/lock a div at the bottom of a column
Aug 17, 2012 2:16 PM
I have a two-column layout. At the bottom of both is a small, yellow div. The div on the right side is below the text but I would like to have it at the bottom of the column to match the left-hand side.
www.ourhealthcarecrisis.com
    Aug 17, 2012 5:49 PM   in reply to Acemon99
    if the objects are less yellow divs, then you simply set an id for each, and using CSS to use margin-top to concidir the two divs.
    ____________________________________________
    administrador -  (link removed by moderator)
    Aug 18, 2012 11:02 AM   in reply to Acemon99
    .constitution3 {
        margin-top: 40px;  /**adjust as needed**/
    Nancy O.
