File reference in my EDL exports incorrect (R3D)
Aug 16, 2012 11:04 AM
Tags: #speedgrade #edl
Before I start my gear:
Premiere Pro CS6 (latest update) via Windows 7 64 bit.
Speedgrade CS6 (latest update)
Handling RED ONE R3D Files (directly editing RAW data)
What I'm trying to do
Adobe Premiere Edit > export EDL > Speedgrade > import EDL > Link Clips (wont work)
The Issue
I've been trying to get an EDL imported and linked to its clips into speed grade via Adobe Premiere CS6 with no avail.  Although I was able to import the EDL I was unable to link the RAW R3D files to the clips.
After hours of investigation I've narrowed it down to the fact that the EDL being exported from PPro has the incorrect file reference.
The EDL below refers to the file by 'A029C023' when it should be 'A029_C023_04203V_001' (when I manually renamed it then I was able to 'Load from desktop' from speedgrade)
Could someone tell me why this is happening?  My final edit has hundreds of edit points and it would be unrealistic to manually change all the file names.
Any help would be MUCH appreciated!!
Cheers,
TITLE: EDLTEST2
001  BL       V     C        00:00:00:00 00:00:06:05 00:00:00:00 00:00:06:05
002  A029C023 V     C        15:35:09:16 15:35:27:20 00:00:06:05 00:00:24:09
* FROM CLIP NAME: SC4-2-WS
003  A029C023 AA    C        15:35:09:16 15:35:27:20 00:00:06:05 00:00:24:09
004  A029C054 V     C        18:02:07:14 18:02:32:11 00:00:24:09 00:00:49:06
* FROM CLIP NAME: SC4-8-MCU
005  A029C054 AA    C        18:02:07:14 18:02:32:11 00:00:24:09 00:00:49:06
006  A029C047 V     C        17:32:17:08 17:32:30:05 00:00:49:06 00:01:02:03
* FROM CLIP NAME: SC4-15-MCU
007  A029C047 AA    C        17:32:17:08 17:32:30:05 00:00:49:06 00:01:02:03
    Aug 17, 2012 9:01 AM   in reply to kaljack22
    I just don't have any R3D clips to test with.
    Aug 17, 2012 12:06 PM   in reply to kaljack22
    I don't know that.
    However, when I tested the EDL option to SpeedGrade with other media, it worked just fine.
    Aug 17, 2012 5:17 PM   in reply to Jim Simon
    Yes, it looks like it's using the reel or tape name. If you remove this data does it then use the filename instead?
    Sep 2, 2012 7:01 AM   in reply to kaljack22
    It sounds like things just don't work the way they should.  That means a Feature Request is in order, a lot of patience on your part, and in the meantime, another method of getting the job done besides EDL.
