Image Color, Print Settings Dialogue Box CS6
Aug 14, 2012 8:51 AM
The soft-proof of an image in CS6 gives a very good rendering based on a given paper profile for my printer. However subsequently, with proper settings in the Print Settings dialogue box, the image represented often has colors that are far from the earlier soft-proof rendering and are thoroughly inaccurate. The image prints correctly, having no resemblance to the image appearing in the dialogue box, but coming quite close to the soft-proof simulation. Is something amiss? On a system running Mac OS 10.8.
    Aug 14, 2012 2:34 PM   in reply to Ralph Eisenberg
    Do you have the Match Print Colors and Show Paper White options on?
    Aug 16, 2012 4:29 PM   in reply to Ralph Eisenberg
    It's strange that you are getting a different result on screen but your prints come out fine. Could you post a screenshot of your Print dialog? Make sure the Color Managment settings are displayed.
    Aug 17, 2012 9:13 AM   in reply to Ralph Eisenberg
    Yes, that's what I meant by "on screen", I wasn't refering to the soft proofing, just the Print dialog. Which is why I'd like to see your Print dialog, to check it's settings.
    Aug 17, 2012 12:38 PM   in reply to Ralph Eisenberg
    I tried to duplicate all of your settings (but I do not have your printer, nor a printer that allows for sending 16-bit data) and I'm not seeing what I'd call a drastic color shift (very slight desat of the reds it seems).
    I assume you've calibrated your monitor with a device, so you are using a custom display profile.
    In the very least, this is a minor issue as the print comes out correct (most important) and soft-proofing is working in the application. It's just an issue of the soft-proofing in the print dialog that's giving you an issue, which could be ignored.
    Perhaps we need some input from someone with the same printer?
  • Noel Carboni
    Dec 23, 2006
    Aug 17, 2012 5:37 PM   in reply to Ralph Eisenberg
    Can you please take screenshots of an image where there is little resemblance as you put it, showing the differences?
    It would be helpful to know the color space of the image as well (e.g., do you see more of a disparity with ProPhoto RGB images?).
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Aug 18, 2012 7:18 AM   in reply to Ralph Eisenberg
    Is there any way you could screen grab the display showing the soft proof and post that image as well so the colors could be compared directly?
    I'm working on a theory...  In the past I've seen the color-management, when done in the GPU (modes Normal and Advanced), do an inaccurate job of transforming colors to the monitor display specifically when the ProPhoto RGB profile is in use.  This apparently does not happen when the color-management is done in the CPU.  Adobe has known about this since quite a long while back and hasn't fixed it.
    Would you be willing to try an experiment?  Go into Preferences - Performance, click the [Advanced Settings] button, and choose Basic mode.  Then Quit Photoshop and restart.  Do you see the same differences?
    -Noel
