Autumnmantis
Luminance Formulae and Red Distortion
Aug 14, 2012 8:28 PM
Tags: #conversion #greyscale #formula #luminance #lightness #709 #coefficients
I'm working on a chart that displays and names a couple hundred color swatches.  I have all of their color data in a table, and I want to arrange them by hue and lightness, so I applied the Rec.709 coefficients to my data.  This arranges my colors into a natural gradient--except for the reds, which have some glaring missplacement.  Any idea why .709 coefficients do this, or what coefficients I should use instead?
    Aug 14, 2012 10:55 PM   in reply to Autumnmantis
    Your observation is correct, like here in chapter 7:
    http://www.fho-emden.de/~hoffmann/gray10012001.pdf
    It's the Helmholtz-Kohlrausch effect/phenomenon.
    The effect is taken into account in Mark Fairchild's
    Color Appearance Models.
    http://www.google.de/search?hl=de&as_q=Fairchild&as_epq=Color+appearan ce&as_oq=&as_eq=&as_nlo=&as_nhi=&lr=&cr=&as_qdr=all&as_sitesearch=&as_ occt=any&safe=images&as_filetype=&as_rights=
    Using Lab (CIELab) or even Munsell wouldn't improve the
    situation, in my opinion. For me, saturated red/orange
    appears brighter than gray or blue in planes of constant
    Lightness (Lab) or Value (Munsell).
    http://www.fho-emden.de/~hoffmann/cielab03022003.pdf
    http://www.fho-emden.de/~hoffmann/munsell15052009.pdf
    Best regards --Gernot Hoffmann
    Aug 15, 2012 8:52 PM   in reply to Autumnmantis
    Thanks to Prof Hoffman as usual. I am glad he is again contributing to the forum.
    Aug 16, 2012 4:50 AM   in reply to Autumnmantis
    Autumnmantis and Lundberg,
    thanks for the feedback. In my opinion there are two mistakes:
    a) wrong exponent (G instead of 1/G)
    b) wrong concept - the ordering sequence does not depend on
    gamma encoding.
    This formula delivers the CIE(1931) luminance Y in linear coordinates,
    specifically for Rec-709 primaries and D65 white:
    r=0.2126
    g=0.7152
    b=0.0722
    Y = rR + gG + bB
    Gamma encoded values are characterized by an apostroph, but we
    have to apply an inverse exponent k=1/G = 1/2.2, because the monitor
    applies a transform with exponent G to data (rule of thumb).
    R'=R^k
    G'=G^k
    B'=B^k
    Y' = rR' + gG' + bB'
    Now let's assume, we have sorted some colors by their luminances:
    Y1<Y2<Y3...
    How would the gamma encoded numbers be sorted?
    Probably exactly  in the same order (I thought I had proved this
    mathematically, but who knows):
    Y1'<Y2'<Y3'
    Therefore no gamma encoding can cure the Helmholtz-Kohlrausch-
    "problem" - sorting by perceived lightness (by brightness).
    There are other problems - the perception  of a color depends
    much on the environment.
    Autumnmantis, what exactly is your application?
    Aug 16, 2012 1:27 PM   in reply to Autumnmantis
    Things you might want to read:
    http://www.poynton.com/notes/colour_and_gamma/GammaFAQ.html
    http://www.poynton.com/notes/colour_and_gamma/ColorFAQ.html  Particularly section 9.
    You have gamma encoded RGB values, you need to convert those to linear values, then apply the weights to calculate Y.
    Aug 17, 2012 4:07 AM   in reply to Autumnmantis
    Autumnmantis,
    you're right, my assumption that sorting by linear luminance Y
    or - alternatively - gamma encoded luminance Y' should deliver
    the same sequence, is probably wrong. Thanks for insisting.
    Anyway, there is - in the sense of CIE(1931) colorimetry - only one
    correct approach, here for rec.709 and D65:
    Convert the gamma encoded file data R', G', B' into data R,G,B
    in the linear space X,Y,Z and calculate Y, the true CIE luminance:
    Y = r R'^e + g G'^e + b B'^e  with exponent e=gamma=2.2.
    The Helmholtz-Kohlrausch effect isn't  part of the CIE colorimetry,
    therefore this sorting doesn't deliver a visually correct sequence.
    According to Poynton (quoted below):
    http://www.poynton.com/notes/colour_and_gamma/ColorFAQ.html#RTFToC11
    in video technology a linear combination of R',G',B', called
    Luma,  is used as a substitute for luminance Y:
    The coefficients that correspond to the "NTSC" red, green
    and blue  CRT phosphors of 1953 are standardized in ITU-R
    Recommendation BT.  601-2 (formerly CCIR  Rec.  601-2).
    I call it Rec.  601.
    To compute nonlinear video luma from nonlinear red, green
    and blue:
    This well known formula is often applied to sRGB though it is based
    on NTSC primaries and illuminant C whitepoint.
    You may try sorting by Luma...
    Here's another attempt how to sort colors for special purposes:
    http://www.fho-emden.de/~hoffmann/palette30082003.pdf
    Aug 17, 2012 2:20 PM   in reply to Autumnmantis
    Yes 2.2.
    Think about 50% gray -- you have a gamma encoded value of 127/255, that should map to a linear value near 18% (reflectance matching 50% perceived lightness).
    127/255 ^ 2.2 = 0.216
Bookmarked By (1)
