segato@hotmail.com
Simple triangle
Aug 17, 2012 2:00 PM
How do you make a tringle in cs6 FW? When creating a polygon there is no sides in properties window?
    Aug 17, 2012 4:53 PM   in reply to segato@hotmail.com
    Use the Smart Polygon tool and reduce the number of sides to 3.
    Aug 17, 2012 9:43 PM   in reply to segato@hotmail.com
    As an alternative, I'm a fan of drawing a square and then deleting one of its points. (In FW, this would mean drawing a rectangle while holding the Shift key, then selecting a point with the Subselect tool, opting to ungroup the rectangle, and deleting the point.)
    It's odd that there'd be no sides in the Properties inspector when working with the standard Polygon shape.
    Aug 17, 2012 11:35 PM   in reply to segato@hotmail.com
    This is what you should see if you have a Smart Polygon selected. Have you ungrouped the shape? You loose the editability if you do.
    Aug 17, 2012 11:49 PM   in reply to segato@hotmail.com
    Excellent!
    Aug 18, 2012 8:51 AM   in reply to segato@hotmail.com
    One more tip: When using the standard Polygon tool, you'll need to set the number of sides before drawing the shape. That's when those options appear in the Properties inspector. After the shape is drawn, you'll see a different set of options, as in your first screenshot.
