jasonmahaffey12
Is there a way to save an image file as a jpeg and add -web or -print to the file name?
Aug 17, 2012 5:45 PM
Tags: #image #cs5.5
I am trying to find a way to save my image file as a jpeg and add -web or -print to the existing file name.  This way I can easily see which files are lower resolution for web posting or high resolution for printing.
  • Noel Carboni
    Dec 23, 2006
    Aug 17, 2012 6:00 PM   in reply to jasonmahaffey12
    Is changing the name by typing a few extra characters in the filename in the Save dialog not working for you?
    -Noel
    Aug 17, 2012 6:07 PM   in reply to jasonmahaffey12
    If you want it done automatically via Save for web,here's a way make presets for that:
    http://forums.adobe.com/message/1528591
    Aug 17, 2012 6:39 PM   in reply to jasonmahaffey12
    HTML is part of a drop down menu,click on it and chose "Saving Files"
    Aug 17, 2012 7:07 PM   in reply to gener7
    I'm kind of flummoxed myself. I thought this method would append -"web" to a filename but it's not working. It's like I got the right settings in the SFW dialog box,but it ain't happening.
    Aug 17, 2012 8:51 PM   in reply to jasonmahaffey12
    I've been pounding at the SFW idea,but not getting it to work. What you want can probably be accomplished with an action or script,but that's beyond what I know. Perhaps better minds can work it out. Sorry Jason, I thought I had solved it.
    Gene
    Aug 17, 2012 9:34 PM   in reply to jasonmahaffey12
    Jason,
    I helped somebody do a very similar thing about a week ago.
    The trick is to use the Batch command's ability to construct a file name.
    Tell the batch to append, e.g. "-x" without quotes, to the name of each saved file.
    The batch runs an Action which does a save as JPEG, resize image, add logo, save as JPEG, then close document.
    The output is "<document name>-x.jpg" and "<document name>-x-x.jpeg".
    Then use Windows Explorer to rename "*-x-x.jpg" to "*-print.jpg".
    Then rename "*-x.jpg" to "*-web.jpg".
    See http://forums.adobe.com/thread/1038992?start=32
    The name construction that I used there was just an "x" appended to the document name. Use whatever you like. Also juliew subsequently referred to the method as a "double-batch" run, although it is not. One run of the batch will output two JPEGs for each input document.
    I hope the disagreements in that thread don't cause too much disruption.
    If you want, the Batch command itself can be recorded in another Action which would store the parameters of the batch, then you could run that Action anytime without having to set up the details of the batch each time. It would always output to one specific folder, though.
