Can't uninstall Flash Player 9.0.45.0
Jul 21, 2012 2:10 PM
I use Opera as my default browser and have problems due to Flash Player 9, where I get debug errors, etc for several sites that are not Flash based but apparently have Flash elements on them. I've tried all of the steps listed on Adobe's site (run the uninstaller, delete files in several folders, etc, then reboot), but when I go back to the help page to check my Flash player's status, I  see that Flash player 9.0.45.0 is still running! I've even gone into the Registry to try to remove the Safe Versions folder as suggested in another support thread, but there is no Safe Versions folder in my Registry. This problem locks up my browser and is extremely frustrating. Any help would be appreciated. Thanks
    Jul 21, 2012 7:29 PM   in reply to BruceMCE
    Where do you have that Flash Player version installed?  I do not know Opera, but the browser should be able to tell you where it is.
    Jul 23, 2012 6:28 PM   in reply to BruceMCE
    You need to tell us a little bit more...
    What is your operating system & version?
    Can you search your hard disk for NPSWF* ?
    What is the exact error message when you try to install a newer FP version?
    In Opera, can you find other installed plugins, but not FP?
    Jul 24, 2012 10:51 PM   in reply to BruceMCE
    BruceMCE wrote:
    I found 6 instances of NPSWF. Should I delete all of them?
    I wouldn't recommend that; can you tell me where these are located, and the full file names?
    I will, over the next days, install Opera on my Windows 7 machine, then see how Opera works.
    Aug 15, 2012 6:57 AM   in reply to Pat Willener
    Hi Pat,
    I am having very similar problem as Bruce for my Opera that Flash Player ver.9 cannot be uninstalled for allowing the newest flash player ver. 11 install and replace the older version. I have followed all the steps in Adobe help by downloaded the uninstall program to uninstall the Flash Player and even using TuneUp Utilities 2012 program to remove all Opera related registries after uninstalled Opera. Hoping that it will have a clean start to install latest version Opera Ver. 12.01. After installed the clean copy of Opera, then installed the Flash Player 11, a message indicated that it is successfully installed. Went back to Adobe and check for flash player version installed in Opera, still showing ver. 9.0.45.0.
    OS: Win 7 (32 bits)
    Also found NPSWF in C:\Program Files\Opera\program\plugins
    When using facebook in Opera, the following error messages kept popping up:
    VerifyError: Error#1033: Cpool entry 38 is wrong type & ReferenceError #1065 Variable SoundPlayer is not defined.
    When logging on to gmail, the following errors popped up and then hanged Opera. Forced closing is required:
    Error: Error#2099: The loading object is not sufficiently loaded to provide this information at flash. display::LoaderInfo/get loader[] at com.google.uploader..FailUploader$init[]
    Error#2044: Unhandled IOErrorEvent: text=Error #2036: Load Never Completed.
    Hoping the photos and above information can help you to tickle the problem in Opera.
    Look forward to your good news!!
    Aug 16, 2012 11:19 PM   in reply to is300hk
    Using Opera, go to http://helpx.adobe.com/flash-player/kb/find-version-flash-player.html - what version does it show as installed?
    I have just installed Opera, and I don't have anything in C:\Program Files\Opera\program\plugins except a readme.txt file.
    Try the following:
    • close Opera
    • open a Command Prompt (Start | Run | cmd)
    • navigate to C:\Program Files\Opera\program\plugins
    • type regsvr32 /u npswf32.dll
    • exit
    • uninstall Opera
    • delete the Opera folder under C:\Program Files
    • reinstall Opera
    Now check the Flash Player version again at http://helpx.adobe.com/flash-player/kb/find-version-flash-player.html
    Aug 17, 2012 11:27 PM   in reply to Pat Willener
    Thanks a lot Pat!  Also got it working with latest flash player in Opera!!  So happy ^=^
    Aug 24, 2012 11:53 PM   in reply to Pat Willener
    Hi Pat,
    It is me again.
    Just installed to the newest flash player version:  11.4.402.265.
    IE is showing this latest version but my Opera still showing: 11.3.300.271
    Tried to repeat the same procedures as for solving update from version 9 to 11.3.300.271  but did not work this time.  This is so wierd that every update installation never get done and always needing to do something?  Pls help so that my Opera browser can keep up to date for the latest flash player.
    Thks
    Aug 25, 2012 12:32 AM   in reply to is300hk
    What files do you have in
    • C:\Program Files\Opera\program\plugins ?
    • C:\Windows\system32\Macromed\Flash ?
    Aug 25, 2012 2:13 AM   in reply to Pat Willener
    Nothing in  C:\Program Files\Opera\program\plugins (just a readme.txt)
    C:\Windows\system32\Macromed\Flash have the followings:
    Flash32_11_3_300_271.ocx
    Flash32_11_4_402_265.ocx
    FlashInstall
    flashplayer.xpt
    FlashPlayerPlugin_11_3_300_271
    FlashPlayerUpdateService
    FlashUtil32_11_3_300_271_Plugin
    FlashUtil32_11_4_402_265_ActiveX.dll
    mms.cfg
    NPSWF32_11_3_300_271.dll
    Aug 25, 2012 6:43 PM   in reply to is300hk
    Looks like the update only installed the ActiveX (for Internet Explorer), but not the plugin.
    Manually download and run the plugin installer from http://helpx.adobe.com/content/help/en/flash-player/kb/installation-pr oblems-flash-player-windows.html#main-pars_header
    Restart Windows after that to make sure the old 11.3 files are deleted.
    Aug 26, 2012 5:34 AM   in reply to Pat Willener
    Dear Pat,
    It is now working and got updated to version 11.4.402.265 for Opera too.
    Wonder if I always need to make extra effort to check and install flash player in Opera plugin myself for all future updates in the future?
    Thks!!!
    Aug 26, 2012 10:00 PM   in reply to is300hk
    Minor updates should install automatically in the background; bigger version updates (e.g. from 11.3 to 11.4) will push a manual update.
