Hello,
Can anyone tell me how you add drop down menus to the items in a spry menu bar that open up upon rolling over the items?
Basically, you need a list with sub-menu items and Spry classes.
<ul>
<li>List Item 1 <ul>
<li>sub-item 1.1</li>
<li>sub-item 1.2</li></ul>
</li>
<li>List Item 2 <ul>
<li>sub-item 2.1</li>
<li>sub-item 2.2</li></ul>
</li>
</ul>
For detailed answers we need to see your page. Can you post a link?
Nancy O.
Hi, thanks for your reply.
I don't have this page online its just something I would like to know how to do in case I want to use it on a web site later.
I wouldn't know how to write this code. In dreamweaver help it said to use the property inspector by selecting the item on the Spry menu, which I did
but then it said you need to find its name in the property inspector but I couldn't find it. Is there a way you can use the property inspector to do it?
DaisPeach
I successfully made the sub menus. This is how I did it- To make the Spry menu,
-Insert> Spry> Menu bar
To add the sub menus-
-Select the tab for the menu above it in design view
-in the property inspector select the item you want to add a sub menu item to and click + to add, - to get rid of one
-in preview the drop down behavior happened upon rolling over the Items
I noted that code was added similar to that in the reply above.
DaisPeach
