Hello,
I have an AE template and i want to display the logo in color with remove the gray strok around the logo. How can i dot that. please ?!
Template:
http://extabit.com/file/28dx638c460vf
Q8Xbox
I can't work out how to use the link you've posted - it just links to download managers and other junk.
Without seeing the problem, it's impossible to answer your question. Being new to After Effects, start at the beginning:
http://blogs.adobe.com/toddkopriva/2010/01/getting-started-with-after- eff.html
You have to click on I have no money, I want download for free bottom of the site or try one of the links below. I will see the link you provided for sure...
http://depositfiles.com/files/vdu925i4k
http://www.unibytes.com/9WR9-EKfZwELqw-Us4P3UgBB?drgn=1
http://rapidgator.net/file/29895254/Shape_Animation_Logo_sl2_120804_12 -03.7z.html
http://lumfile.com/7fsb3bwggm70/Shape_Animation_Logo_sl2_120804_12-03. 7z.html
I don't know what kind of file you're trying to get us to download. The file extension is .7z. It's about 18 MB.
If you want us to download an AEP file or take a look at a project then you must supply it in a standard format. No funny compression. There's too much danger in pulling down files that we can't identify.
If you have a screenshot of your project that would probably be enough to get us started. The only thing I know is that you want to change color.
Agreed. Every link posted so far has been from some shonky site which encourages the user to download all sorts of junk, and the files themselves seem to be unidentifiable.
Just upload the .aep file using this forum or Yousendit or something. I'm not prepared to download any of the stuff you've linked to.
Your project included everything but the Logo. If you open the My Logo comp you'll see that there are two layers. Envato_Network.ai and cr4anime-e5adc49526.png
If this is where you want to change the color then you'll have to open the .ai file in Illustrator and change the color or open the .png file in Photoshop and change the color there.
I'm still not sure what you want us to help you with.
Ok, I will explain more. I have export the file and play it on GomPlayer as you can in the image below the logo display in gray color only not in full color. What i want is to display the logo in full color and remove the gray color around the logo. How to do that ?
http://imageshack.us/photo/my-images/26/82919962.jpg
original logo
http://imageshack.us/photo/my-images/94/cr4animee5adc49526.png
If you are using the .png file in your video then you have something fouled up in your color/render settings. It's impossible to tell from the files you've sent or the information you've given. If there is a difference between what you see in the Composition window and the final render then the problem is there. IF the problem is in the composition window then there's something else wrong.
