MaikoRocha73
LR4 crashes on load on OS X Mountain Lion
Aug 18, 2012 1:48 PM
Tags: #@executable_path/../frameworks/asneu.framework/versions/a/asneu
I've installed LR4 from the Mac App Store and I get the following error message when I try to run it. I've also tried to reinstall it twice and rebooting after reinstalling but the problem remains.
It says it cannot find @executable_path/../Frameworks/asneu.framework/versions/a/asneu but I checked the Contents and it is there on Applications/Adobe Photoshop Lightroom 4.app/Contents/Frameworks/asneu.framework/Versions/a/aseneu
Process:         Adobe Photoshop Lightroom 4 [547]
Path:            /Applications/Adobe Photoshop Lightroom 4.app/Contents/MacOS/Adobe Photoshop Lightroom 4
Identifier:      com.adobe.Lightroom4
Version:         4.1 (4.1)
App Item ID:     506734677
App External ID: 8187632
Code Type:       X86-64 (Native)
Parent Process:  launchd [233]
User ID:         501
Date/Time:       2012-08-18 13:18:04.180 -0700
OS Version:      Mac OS X 10.8 (12A269)
Report Version:  10
Interval Since Last Report:          708019 sec
Crashes Since Last Report:           206668
Per-App Crashes Since Last Report:   6
Anonymous UUID:                      4FF6C537-C4AE-47B6-B0EA-C1567F15BE3F
Crashed Thread:  0
Exception Type:  EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
  Library not loaded: @executable_path/../Frameworks/asneu.framework/versions/a/asneu
  Referenced from: /Applications/Adobe Photoshop Lightroom 4.app/Contents/MacOS/Adobe Photoshop Lightroom 4
  Reason: image not found
Binary Images:
       0x100000000 -        0x10000cfff +com.adobe.Lightroom4 (4.1 - 4.1) <C0AEF936-5894-6669-91CB-E4C8C0209503> /Applications/Adobe Photoshop Lightroom 4.app/Contents/MacOS/Adobe Photoshop Lightroom 4
       0x100016000 -        0x10005afff +com.adobe.ag.kernel (AgKernel Version 1.0 - 1.0) <E89171B4-B3F5-01D5-A2F0-15F4B192107A> /Applications/Adobe Photoshop Lightroom 4.app/Contents/Frameworks/AgKernel.framework/Versions/A/AgKernel
    0x7fff64cad000 -     0x7fff64ce193f  dyld (210.2.3) <A40597AA-5529-3337-8C09-D8A014EB1578> /usr/lib/dyld
    0x7fff8886a000 -     0x7fff89494fff  com.apple.AppKit (6.8 - 1187) <C9309F5C-9441-3E5B-A120-B03FEDDA63F9> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff8f9a3000 -     0x7fff8fcffff7  com.apple.Foundation (6.8 - 945) <0C972F73-0C07-3384-98F2-B176E0289494> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
Model: MacBookPro6,2, BootROM MBP61.0057.B0F, 2 processors, Intel Core i5, 2.4 GHz, 8 GB, SMC 1.58f16
Graphics: Intel HD Graphics, Intel HD Graphics, Built-In, 288 MB
Graphics: NVIDIA GeForce GT 330M, NVIDIA GeForce GT 330M, PCIe, 256 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1067 MHz, 0x80CE, 0x4D34373142353237334348302D4348392020
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1067 MHz, 0x80CE, 0x4D34373142353237334348302D4348392020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x93), Broadcom BCM43xx 1.0 (5.106.98.81.20)
Bluetooth: Version 4.0.9f8 10405, 2 service, 18 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: M4-CT512M4SSD2, 512.11 GB
Serial ATA Device: MATSHITADVD-R   UJ-898
USB Device: hub_device, 0x0424  (SMSC), 0x2514, 0xfa100000 / 2
USB Device: Datacolor Spyder3, 0x085c, 0x0300, 0xfa140000 / 6
USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0236, 0xfa120000 / 5
USB Device: BRCM2070 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000 / 4
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8218, 0xfa113000 / 8
USB Device: Internal Memory Card Reader, apple_vendor_id, 0x8403, 0xfa130000 / 3
USB Device: hub_device, 0x0424  (SMSC), 0x2514, 0xfd100000 / 2
USB Device: USB to ATA/ATAPI Bridge, 0x152d  (JMicron Technology Corp.), 0x2329, 0xfd130000 / 5
USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd120000 / 4
USB Device: Built-in iSight, apple_vendor_id, 0x8507, 0xfd110000 / 3
    Aug 18, 2012 3:01 PM   in reply to MaikoRocha73
    Here is a real shot in the dark:
    (1)  Repair Permissions and try launching Lightroom.
    (2)  Did you install Lightroom in the default folder:  /Applications and not ~Applications  (It shouldn't matter but...)
    (3)  Check your permissions for Lightroom.  Do you have 'execute' privileges?
    Aug 18, 2012 4:11 PM   in reply to MaikoRocha73
    Try contacting the App Store:  http://www.apple.com/support/mac/app-store/
    In your position, I'd try for a refund from Apple and simply download Lightroom directly from Adobe.
