Reconstruct Blu-ray project from burned disc
Aug 12, 2012 2:21 PM
I have burned the project to BD and save the files in the project folder.
However, on the disc, the files is muxed.
In the old day of DVD, demux is pretty easy to get back m2v and ac3.
In the base of BD, how do get back m4v and ac3?  Is there a demuxer that can do this?
    Aug 12, 2012 2:35 PM   in reply to Howard Hoffman
    Google or Bing for Clown BD. Windows only.
    Jeff
    Sent from my iPhone
    Aug 12, 2012 3:05 PM   in reply to Howard Hoffman
    Encore accepts .264 files, as does the AME.  Along with the .264 file, Clown BD will create either a TS file, an M2TS file, an M2TS file in a Blu-ray folder structure, or a Blu-ray + ISO.  Why do you need the M4V file?
    Jeff
    Aug 12, 2012 3:14 PM   in reply to Howard Hoffman
    I may not understand exactly what you're trying to do or how you're trying to do it, but have you tried the Replace Footage command?
    Aug 13, 2012 8:12 AM   in reply to Howard Hoffman
    If you only need to change the menu, the video files can be ripped of the BD. Look in the stream folder they are the m2ts files. Use them instead.
    Aug 13, 2012 9:14 AM   in reply to Ann Bens
    Ann is correct.  To clarify, your M4V and AC3 files are gone forever.  When En built the Blu-ray disc, they were transcoded and converted into muxed M2TS files and put in the Stream folder on the disc.
    You will have to use the ripped, muxed files to replace the menu background videos in the project.  It should be as easy as re-linking the Video and Audio controls of the Motion tab of the Menu Properties to the muxed M2TS assets.
    Jeff
    Aug 13, 2012 1:43 PM   in reply to Howard Hoffman
    Those m2ts files will not be re-encoded so no need to demuxe.
    Aug 13, 2012 2:01 PM   in reply to Ann Bens
    I think he is wanting to get the video/audio for his timelines, not the menu. Can he do a replace for those original assets with an m2ts?
    Aug 13, 2012 2:31 PM   in reply to Howard Hoffman
    Try replace asset or delete the m4v and ac3 and insert th m2ts on the timeline.
