Set page and printer options
Aug 18, 2012 11:27 AM
    Aug 18, 2012 11:27 AM   in reply to Community Help
    Every time I try to print a project the HP Fax dialog box opens. I have gone to File>Print>Select Printer, and File>Print>Change Settings>...   Both show using the correct printer, NOT the fax. BUT, when I select Advance Settings from the Change Settings dialog box, the top of the next box that opens indicates it is for FAX Document Properties. I do not a phone line to use as a fax, and I deleted the old information. Please HELP! Thank you very much, Kim Wiechers, kwiechers@comcast.net, 816.654.4053
    Aug 18, 2012 11:46 AM   in reply to KimRene1856
    The names of the printer and fax are very similar and Elements gets "confused."
    Go to Control Panel>printers and faxes>right click the default printer>go to Printer properties, then rename the printer with a short name.
    Aug 18, 2012 8:58 PM   in reply to hatstead
    Thank you so very much for the fix.
