a_sands98
Help with ID free trial from the Creative Cloud
Aug 18, 2012 5:02 PM
I'm using the trial version of the Creative Cloud (on a PC with Windows XP) and had success downloading. However, when I try to launch the application ID I start receiveing errors.
For example."The procedure entry point GetLogicalProcessorInformation could not be located in the dynamic link library KERNEL32.dll." was one error I recieved.  Then, "Cannot load the DYNAMICDOCUMENTS.RPLN plug-in. It is dependent on the TRANSPARENCY.RPLN plug-in, which failed to load. Please check documentaion for the TRANSPARENCY.RPLN plug-in." Then there will be another error about SVG EXPORT.APLN plug-in.
Then ultimately I get the force close error and it shuts down the app.  Is it a system error or application??
    Aug 18, 2012 9:52 PM   in reply to a_sands98
    You are recieving 2 error :-
    This particular error means that you have a problem with your OS install (it's missing a function that should be there).
    And is there any chance that you had problems installing one of the OS service packs?
    Upgrade to Win XP SP3 and then check.
