Beefsticks
CS6 temp file blunder - can you repeat this problem?
Aug 18, 2012 1:38 PM
Tags: #problem #crash #bug #glitch #cs6 #temp #admin
There is a serious root problem with Adobe's implemented permissionless-temp-file creation methods (pun intended.) The problem is that during startup, both Bridge and Photoshop CS6 try to make temp files on the root folder of the OS drive. Its affecting many peoples' installations by crashing them on application launch if not run by the super-administrator account on the computer. Adobe says to just run as admin to fix it, which does fix the start up crash. However, for me, it creates a gigantic problem: it breaks OS-to-PS and OS-to-Bridge drag and drop functionality completely!!! I literally was slowed to a crawl in my workflow having to import photos 1 at a time through the file-> open menu because I couldn't drag and drop various files from various locations on my computer. Not everything is clumped in 1 area neatly for Bridge to open everything, and I never realized just how much I used this function until this run as admin band-aid broke it. Eventually I fixed the CS temp location after 10-12 hours of hair pulling research and trial and error, and I finally have Photoshop CS6 working without admin permissions and everything is dandy with drag and drop, but only in PS. Bridge still cannot be run without administrator privileges and cannot have files dropped in or out of it to or from Explorer, and I am getting really frustrated here.
Its kind of disheartening that I have to work for 10 hours in order for me to be able to pay and fully utilize Adobe's software. Even 3 months after being made aware of this issue in other forums, and for how many people it is affecting, they still don't fix it when all they need to do is move the default location of the temp file to somewhere without a need for admin permissions! (I.E. documents folder?)
So does anyone else find their drag and drop ability gone once running Bridge/PS CS6 in admin mode? Am I the only one? Is there a way to move the default temp creation location of Bridge as well? I'm frustrated and I think Adobe seems to be taking this permissions issue way too lightly!
  • Noel Carboni
    Dec 23, 2006
    Aug 18, 2012 1:46 PM   in reply to Beefsticks
    I read your message and I honestly can't tell which OS you're using.  Perhaps that would be helpful.
    I run with UAC disabled on Windows 7, myself, which is essentially running As Administrator all the time.  I have no problem with drag and drop.
    And as far as I can see, since I have C: set as my only scratch drive, Adobe uses my TEMP folder (which is pointed at C:\TEMP courtesy the TEMP and TMP environment variables).
    Let's try to diagnose the problems you appear to be trying to work around first...
    What OS?
    Exactly what does it do wrong if you don't run As Administrator?  Maybe show screenshots.
    What's your TEMP environment variable set to?
    Is there anything special you've done to your system?
    -Noel
    Aug 18, 2012 2:53 PM   in reply to Beefsticks
    Photoshop does not create the TEMP folder - that is an OS variable, and the folder should already exist.
    And drag and drop problems are most likely unrelated to permission levels or temp file location.
    >> Temp is actually on my RAMdisk
    Bad idea where Photoshop and Bridge are concerned.  It would be faster to use actual RAM, then hit the disk only as needed.  Right now you limit the RAM available, and force them to use scratch more often than they should (and even RAM disks have overhead).
  • Noel Carboni
    Dec 23, 2006
    Aug 18, 2012 5:41 PM   in reply to Beefsticks
    Overfocused wrote:
    Temp is actually on my RAMdisk but using a folder junction to trick the programs into thinking its on the default temp folders of the C drive.
    Therein lies the problem. If you try to trick things you run into trouble.
    Yes, it seems like it should work.
    Windows and all its apps always work best if everything, and I do mean everything is on drive C:.
    In this particular case, relocating things elsewhere does NOT sit well with the Adobe software.  You're not the first to see this.  People with SSDs try to move things off the C: drive and it virtually always leads to trouble.
    You could alleviate all these problems by reorganizing your system so that you have a 2 TB system drive, maybe have some additional drives for data you don't access much in your normal interactive operations, and forget about all the trickery.  Trying additional trickery instead of doing this is just going to buy you more trouble down the line with something else.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Aug 18, 2012 10:07 PM   in reply to Beefsticks
    2TB is the biggest partition Windows 7 can boot from using a MBR (Master Boot Record) setup.  There are ways to go beyond that, but it involves requirements of the computer system that may not be avialable.
    I have a 2 TB SSD array, by the way.  With everything on the array - drive C: - the system just flies.
    -Noel
