Problem with jquery slide show conflict with vertical navigation menu in Firefox & Chrome
Aug 18, 2012 11:21 PM
Tags: none (add) #jquery_cycleProblem with jquery slide show conflict with vertical navigation menu in Firefox & Chrome. Works in IE. This is my first time trying to post a question - so please be kind. I am also not good with code and am finding css a real challenge after learning to design based on tables. I'm using CS5.
The "test" page with the slide show is: http://www.reardanwa.com/index-slides.html The same page without the slide show is http://www.reardanwa.com/
I realize the images are not ideally sized - I'll fix those once I get the pages to function. Maybe I need a different slide show? I would prefer a widget that I can modify to required size & postition. Again - I'm not good at building with code from scratch.
The problem is the naviagation links that are directly next to the slide show do not work in Firefox of Chrome. They do work in IE.
I've read about using jQuery.noConflict(); code but can't figure out the correct way to use it in my case or whether that's even part of the solution. I know my code is not well organized as I have cobbled together from various sources in an attempt to format the page the way the client wants it. Also, FYI, I will eventually try to make the page work in Surreal CMS.
I've spent sevaral days over the last several weeks trying to solve sth slide show/navigation conflict - so any specific light you can shed will be much appreciated.
Thanks in advance.
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Reardan Area Chamber of Commerce</title>
<meta name="description" content="home page for Reardan Area Chamber of Commerce" />
<meta name="keywords" content="Reardan WA, chamber of commerce" </>
<script src="scripts/jquery-1.6.min.js" type="text/javascript"></script>
<script src="scripts/jquery.cycle.all.js" type="text/javascript"> </script>
<script type="text/xml">
</script>
<style type="text/css">
#slideshow {
padding: 10px;
margin:0;
#slideshow-caption{
padding:0;
margin:0;
#slideshow img, #slideshow div {
padding: 10px;
background-color: #EEE;
margin: 0;
body {
font: 100%/1.4 Verdana, Arial, Helvetica, sans-serif;
background: #004B8D;
margin: 0;
padding: 0;
color: #000;
/* ~~ Element/tag selectors ~~ */
ul, ol, dl { /* Due to variations between browsers, it's best practices to zero padding and margin on lists. For consistency, you can either specify the amounts you want here, or on the list items (LI, DT, DD) they contain. Remember that what you do here will cascade to the .nav list unless you write a more specific selector. */
padding: 0;
margin: 0;
h1, h2, h3, h4, h5, h6, p {
margin-top: 0; /* removing the top margin gets around an issue where margins can escape from their containing div. The remaining bottom margin will hold it away from any elements that follow. */
/* adding the padding to the sides of the elements within the divs, instead of the divs themselves, gets rid of any box model math. A nested div with side padding can also be used as an alternate method. */
.left
position:absolute;
left:0px;
.center
margin:auto;
width:95%;
.box
position:relative;
left:-90px;
width:950px;
height:350px;
border-radius: 13px;
-moz-border-radius: 13px;
-webkit-border-radius: 13px;
z-index:1000;
.slide{
position:absolute;
a img { /* this selector removes the default blue border displayed in some browsers around an image when it is surrounded by a link */
border: none;
/* ~~ Styling for your site's links must remain in this order - including the group of selectors that create the hover effect. ~~ */
a:link {
color: #42413C;
text-decoration: underline; /* unless you style your links to look extremely unique, it's best to provide underlines for quick visual identification */
a:visited {
color: #6E6C64;
a:hover, a:active, a:focus { /* this group of selectors will give a keyboard navigator the same hover experience as the person using a mouse. */
text-decoration: none;
/* ~~this fixed width container surrounds the other divs~~ */
.container {
width: 960px;
min-height:900px;
padding:5px 0px 0px 0px;
background: #E8F8FF;
margin: 0 auto; /* the auto value on the sides, coupled with the width, centers the layout */
/* ~~ the header is not given a width. It will extend the full width of your layout. It contains an image placeholder that should be replaced with your own linked logo ~~ */
.header {
padding:10px 5px 0px 5px;
.sidebar1 {
float: left;
width: 225px;
margin: 60px;
color: #FFFF0D;
background: #595FFF;
padding: 5px 5px 0px 5px;
border: 3px solid #F7F723;
z-index:-1;
.sidebar2 {
float: left;
width: 275px;
color: #FFFF0D;
text-align: left;
padding-bottom: 10px;
z-index:2;
.sidebar3 {
float: left;
width: 275px;
color: #FFFF0D;
text-align: left;
z-index:3;
.content {
padding: 0px 0px 0px 0px;
width: 780px;
float: left;
/* ~~ This grouped selector gives the lists in the .content area space ~~ */
.content ul, .content ol {
padding: 0px 15px 5px 10px; /* this padding mirrors the right padding in the headings and paragraph rule above. Padding was placed on the bottom for space between other elements on the lists and on the left to create the indention. These may be adjusted as you wish. */
/* ~~ The navigation list styles (can be removed if you choose to use a premade flyout menu like Spry) ~~ */
ul.nav {
list-style: none; /* this removes the list marker */
border-top: 0px solid #FFFF66; /* this creates the top border for the links - all others are placed using a bottom border on the LI */
margin-bottom: 50px; /* this creates the space between the navigation on the content below */
font: Arial Black, Verdana, , Helvetica, sans-serif;
font-size:1.3em;
font-weight:bold;
z-index:2;
ul.nav li {
border-bottom: 0px solid #FFFF66; /* this creates the button separation */
font: 120%/1.4 Arial Black, Verdana, , Helvetica, sans-serif;
ul.nav a, ul.nav a:visited { /* grouping these selectors makes sure that your links retain their button look even after being visited */
padding: 3px 0px 5px 0px;
display: block; /* this gives the link block properties causing it to fill the whole LI containing it. This causes the entire area to react to a mouse click. */
width: 185px; /*this width makes the entire button clickable for IE6. If you don't need to support IE6, it can be removed. Calculate the proper width by subtracting the padding on this link from the width of your sidebar container. */
color: #FFFF0D;
ul.nav a:hover, ul.nav a:active, ul.nav a:focus { /* this changes the background and text color for both mouse and keyboard navigators */
color: #FFFFFF;
/* ~~ The footer ~~ */
.footer {
padding: 10px 0;
color: #FFFF0D;
position: relative;/* this gives IE6 hasLayout to properly clear */
clear: both; /* this clear property forces the .container to understand where the columns end and contain them */
/* ~~ miscellaneous float/clear classes ~~ */
.fltrt { /* this class can be used to float an element right in your page. The floated element must precede the element it should be next to on the page. */
float: right;
margin-left: 8px;
.fltlft { /* this class can be used to float an element left in your page. The floated element must precede the element it should be next to on the page. */
float: left;
margin-right: 8px;
.clearfloat { /* this class can be placed on a <br /> or empty div as the final element following the last floated div (within the #container) if the #footer is removed or taken out of the #container */
clear:both;
height:0;
font-size: 1px;
line-height: 0px;
</style>
</head>
<body>
<div class="container">
<div class="header"><!-- end .header -->
<a href="#"><img src="images/Chamber-Logo-2.gif" alt="Reardan Chamber Logo" width="187" height="163" hspace="10" vspace="5" align="top" /></a><img src="images/Reardan-Chamber-Title.gif" width="476" height="204" alt="Reardan Area Chamber of Commerce, Dedicated to Preserving and Enhancing Area Businesses" /><p></p>
<p style="color: #F00">This Site is under construction! Please pardon our dust as we create!</p>
</div>
<div class="sidebar1">
<ul class="nav">
<li><a href="about.html">About Us</a></li>
<li><a href="history.html">Reardan History</a></li>
<li><a href="activities.html">Activities</a></li>
<li><a href="business.html">Business<br />
Directory</a></li>
<li><a href="about.html">Join the<br />
Chamber</a></li>
<li><a href="links.html">Links<br />
<span style="font-size: 85%">Tourism</span><br />
</a></li>
</ul>
<!-- end .sidebar1 --></div>
<br />
<br />
<br />
<br />
<div class="box" +"slide">
<script type="text/javascript">
// BeginOAWidget_Instance_2559022: #slideshow
slideshowAddCaption=true;
$(window).load(function() {
$('#slideshow').cycle({
after: slideshowOnCycleAfter, //the function that is triggered after each transition
autostop: false, // true to end slideshow after X transitions (where X == slide count)
fx: 'blindX',// name of transition effect
pause: false, // true to enable pause on hover
randomizeEffects: true, // valid when multiple effects are used; true to make the effect sequence random
speed: 100, // speed of the transition (any valid fx speed value)
sync: true, // true if in/out transitions should occur simultaneously
timeout: 5000, // milliseconds between slide transitions (0 to disable auto advance)
fit: true,
height: '300px',
width: '525px' // container width (if the 'fit' option is true, the slides will be set to this width as well)
function slideshowOnCycleAfter() {
if (slideshowAddCaption==true){
$('#slideshow-caption').html(this.title);
// EndOAWidget_Instance_2559022
</script>
<div id="slideshow">
<!--All elements inside this will become slides-->
<img src="images/100_1537.jpeg" width="600" height="450" title="caption for image1" /> <img src="images/Parade-2011-2.jpg" width="300" height="225" title="caption for image2" /> <img src="images/100_1495.jpeg" width="600" height="450" title="caption for image3" />
<div title="sample title"> Images for slide show will need to be re-sized to fit box to avoid distortion</div>
<img src="images/beach4.jpg" width="200" height="200" title="caption for image4" /> <img src="images/beach5.jpg" width="200" height="200" title="caption for image5" /> </div>
<!--It is safe to delete this if captions are disabled-->
<div id="slideshow-caption"></div></div>
<div class="sidebar2" "anotherClass editable"><p align="center"><strong>Chamber News</strong><br />
Local News item
<br />
Another New item</p>
<p align="center">lots of news this week<br />
<br />
<br />
<br />
</p>
</div>
<div class="sidebar3" "anotherClass editable"><p align="center"><strong>Upcoming Events</strong></p>
<div align="center"> <a href="activities.html" style="color: #FFFF0D">Community wide yard sales</a><br />
<br />
<br />
<br />
<br />
</div>
</div>
<div class="content"><br />
<br />
</div>
<div class="footer">
<p align="center"><span style="font-size: small">Reardan Area Chamber of Commerce</span><br />
<span style="font-size: x-small">info@reardanwa.com - 509.796.2102</span><br />
</p>
<!-- end .footer -->
</div></body>
</html>
