I am unable to open PSE 10 when I select "Edit In" with Lightroom 4.
I have changed Preferences to PSE Editor. I have uninstalled and reinstalled PSE. I am using a MAC. Can someone please help me.
When you click on Choose, you have to navigate to the folder that contains PhotoshopElementsEditor.exe.
On your computer, it is most likely in a different folder than mine, so I can't tell you exactly where to look, it is most likely somewhere in C:\Program Files\Adobe (or C:\Program Files (x86)\Adobe). On your computer, depending on what options you have selected, the .exe may not appear.
I have done all those steps you mention prior to this post. The only difference is that my file does not have a .exe attached to it. It just says Photoshop Elements Editor.
I appreciate your help, but I'm thinking I will have to contact Adobe Monday.
After much research on the internet, many others are having the same problem.
I do very much appreciate your trying to help me.
First you have to blank in the folderoptions in the Windows configuration the setting for hide known extensions, the fifth from above in files and foldersUnfortunetaly it's a Dutch version so you will understand why my English isn't that good. After doing this you will be able to see the .exe extension.
I said specifically that the .exe might not appear if you have certain options set in Windows. If you have found PhotoshopElementsEditor, that is probably the file you should select.
