stock3d
GPS location not saving in LR4.1?
Aug 19, 2012 11:34 AM
Tags: #export #metadata #gps #lightroom4
I am beating my head on a wall trying to export GPS coordinates.  Here's the situation:
Lightroom 4.1
Camera (Canon) RAW imported from camera directly to DNG (no location info present)
Location added via Map module, and additional metadata (Title, Caption, Keywords, Copyright, etc...) added
Save Location not set to Private
Export Metadata settings "Remove location info" is NOT checked (i.e., do not remove it)
I export to JPG and the location is not present.  Flickr cannot see it, and I load it into Photoshop and examine the metadata and location is not there.  I have also used some other online tools to verify it is missing, as well as Geosetter.  If I set it in Geosetter, the data is then there.  However, Lightroom 4.1 is just not saving it, and I have scoured all the settings looking for any other options.
Help?  This is crucial to my workflow and I'd prefer to do as much as possible inside LR and not have to use external tools.
Jeff
  • Victoria Bampton
    Apr 1, 2008
    Aug 19, 2012 11:39 AM   in reply to stock3d
    And Minimize Embedded Metadata options aren't set in the Export dialog either?
    Any chance of a look at one of those files please Jeff?  And a screenshout of your export settings please?  membersATlightroomqueenDOTcom
  • Victoria Bampton
    Apr 1, 2008
    Aug 19, 2012 11:58 AM   in reply to stock3d
    They keep changing the names!   It's now a Metadata section, sorry.  But you have it set to All so that's not it anyway.
    My next port of call would be to try trashing prefs, perhaps even try a clean user account if you want to rule out loads of things in one fell swoop.
    Info here on preferences: http://members.lightroomqueen.com/index.php?/Knowledgebase/Article/Vie w/1148/198/how-do-i-delete-the-lightroom-preferences-file
    It would also be worth double checking that the map location shows up correctly in the Metadata panel.
  • Victoria Bampton
    Apr 1, 2008
    Aug 19, 2012 12:15 PM   in reply to stock3d
    Oh that's good!  Preference files are often the cause of 'general weirdness'.
    If you still have the dodgy ones around, they may be interested in taking a look.
    Aug 19, 2012 12:16 PM   in reply to Victoria Bampton
    Yes, I agree, the possibility exists that the location was not properly assigned in LR.
