Can you add layers below a Composite Layer?
Aug 19, 2012 3:58 PM
Once you create a composite layer at the top of your layer stack w. Option-click on "Merge Visible" in the Layer Panel Menu, is that new layer the only layer that now shows (represents) the image? For instance, if another adjustment layer is added below it, and the Background layer is the only image layer, will the effect of that adjustment be visible? Or do I need to delete the composite layer and create a new one to include the new adjustment layer?
The reason I ask has to do with an illustration (below) I came across from one of Mark Johnson's old NAPP tutorials (Total Control Glowing Montage). In his tutorial "Layer 1" was created as a composite layer of the Background Layer and "Levels 1" which had a Smart Filter applied to it. Then the two "Levels 1" copy layers were added last to fine-tune the effect of the Levels 1 adjustment. Notice they are BELOW the composite layer. Does this work? Thanks.
    Aug 19, 2012 4:22 PM   in reply to *Rich*
    If the layer at top of stack is in Normal blending mode and has no "Blend If" condition and has no (semi-)transparent pixels and has Opacity 100% and Fill 100% and no Layer Style Stroke that causes transparency (a bug) and has no masked-out region, then it will completely obscure the lower layers.
    Your top layer probably obscures everything
    An Adjustment Layer cannot affect a layer that is above it in a stack.
    I take it you created the composite then added two Adjustment Layers which should be affecting the composite. They will have been added immediately above the layer(s) which was targeted at the time. Just drag these two misplaced Adjustment Layers to the top of the stack and they will affect whatever is below them. (Or drag your composite immediately under them.)
    Aug 19, 2012 4:46 PM   in reply to *Rich*
    *Rich* wrote:
    The composite layer at the top of the stack has a "Multiply" blend mode. Would that make a difference? Thanks.
    Yes, very much so. Multiply is a darkening effect (unless working in 32-bit float mode with channel values greater than 1) except when multiplying with pure white.
    I'm now unsure whether you do want to make the composite before adding two Levels adjustments on top of it, or whether you should be making the multiplying composite as the last stage. Can you post a link to the tutorial?
    Aug 19, 2012 5:36 PM   in reply to *Rich*
    OK, according to the steps you listed, my first reply should have been correct. To recap, if you accidentally added the two Levels layers under the already existing composite then drag them above the composite or drag the composite below them.
    Whenever you create a new layer, it will appear above the highest layer that is currently targeted. If no layer is targeted, the new layer will appear at the top of the stack.
    You also can make a new layer appear below the targeted layer by pressing Cmd/Ctrl key while clicking a "new layer" button.
    Aug 19, 2012 6:23 PM   in reply to *Rich*
    *Rich* wrote:
    ... But could you see the effect of them, if the composite layer is set to Multiply blend mode?
    Multiply only darkens; it doesn't completely obscure the layers below unless it darkens to complete black. Therefore expect the adjustment layers below the multiplying layer to contribute to the overall result.
    Hopefully MJ will clarify the exact steps to take. Good luck!
    Aug 20, 2012 9:59 PM   in reply to *Rich*
    Thanks for the update!
