saydesignitaly
Adobe DPS App rejected by Apple
Aug 20, 2012 3:00 AM
An app I created for a client just got rejected by Apple.
The reason given was:
"We were unable to complete your review because we could not install your app on a device.
The UIRequiredDeviceCapabilities key in the Info.plist is set in such a way that the app will not install on an iPad.
Please ensure that the app's UIRequiredDeviceCapabilities key configuration is correct. Attributes should only be placed in the UIRequiredDeviceCapabilities key if the attribute is either required for the function of the application or if it must not be present on the device. "
How am I supposed to change the UIRequiredDeviceCapabilities key configuration?
I thought that the Viewer Builder did that for you. I used V21, as the instructions said to use the most recent version. Could that be the issue?
The app, which is a simple catalogue, ran fine during testing.
What do I need to modify for them to be able to install the app on an iPad?
    Aug 20, 2012 3:17 AM   in reply to saydesignitaly
    was this an iPhone only app?
    —Johannes
    Aug 20, 2012 3:33 AM   in reply to saydesignitaly
    hm, sorry, then someone else has to chime in, don't know what happened.
    maybe a hickup on the viewer builder server, maybe you can rebuild with v21
    with the newest VB.
    —Johannes
    Aug 20, 2012 3:34 AM   in reply to saydesignitaly
    Just to clarify, did you create the developer IPA file and install that on your ipad?
    Alistair
    Aug 20, 2012 3:50 AM   in reply to saydesignitaly
    If I were you, I'd quickly rebuild the folio, as it is, and resubmit. It could just be a glitch. Something similar happened to one of my first apps a long time ago, I just resubmitted asking Apple to look again and it just got approved. If you have time build the IPA file with other UDID's and test on those too, just to make sure. If that works, also point that out to Apple.
    Good Luck
    Alistair
