Hi Folks,
I've built a DVD ISO in En and am using disc-utility to burn my ISO with an external BR burner.
I filmed in 23.976. Edited in 23.976. Transcoded out of after Effecst in 23.976 and all my Encore setting say 23.976.
My issue is that when there is a scene with a pan or tilt, the motion looks like its playing back at 29.976, essentially it looks sped up.
I double checked my TV settings, I do not have any motion-enhanced functions turned on. Double checked it on another player, same issue.
Is this a data rate issue?
I encoded an H264 at out of After efefcts using, 23.976, CBR, at 30MBS.
Any guesses what this may be?
Perhaps sped-up is not the most detailed explanation.
Essentially all the footage looks as expected, cinematic with 24p's inherent motion blur.
However, as soon as the camera pans or tilts, both the move itself and the action in the frame looks like broadcast 30fps. The image looks the way broadcast cameras look, without motion blur. Its as if the motion, in only pan/tilt instances, is somehow being interpreted incorrectly.
As I said, the quicktime's are fine, MXF's are fine. iPad file is fine. SD DVD is fine. Just the Blu-ray.
Wokflow is: Alexa - Davinci to transcode - Avid to sync - AE to Compress for Blur-ray - Encore to build - Disk utility to burn.
We tried other scenes today. Same result.
Perhaps not the best forum to ask but any other Blu-ray burning software to recommend?
Scenarist, DoStudio (now owned by Sony) and BluPrint. But I would focus on the H.264 (or MPEG2) encoding. It is the encoding that is most likely to introduce a problem.
That said, when you import your AE-compressed file into En for authoring to Blu-ray, does the Blu-ray Transcoding Status column show "Do Not Transcode"? If not, that's where the problem is being introduced because En will re-transcode the asset.
Jeff
I came across this thread with a sort of similar problem (my files are 23.976 but appear 29.97 on the project timeline). I haven't viewed my footage on BluRay yet (haven't built the disc), but the timeline shows that the footage has 30 frames per second. In other words, when I move the bar on the timeline and scrub over the video, where the time code reads minute:second:frames the "frames" number goes all the way to 29 before going back to 0.
The rendered h.264BluRay .m4v file is absolutely 23.976fps (rendered with Adobe Media Encoder out of Premiere) and the project is absolutely set up as a BluRay project in Adobe Encore.
What gives?
