PE10 cutting out parts of audio after conforming
Aug 20, 2012 12:47 AM
Tags: #audio #problems #premiere_elements #premiere_elements_10
I had an older version of Premiere Elements (3.0.2) running and tried to install it on a 64 bit Vista machine.  It was horrible, so I decided to try out the trial for the new version 10.  It loads and operates pretty smootly but for some reason when it conforms the audio it is cutting out certain sounds.  The example I have in particular deals with an over the air broadcast from my hauppauge TV card.  The card can automatically convert the video to an MPEG and it plays fine in the WM player or VLC, however if I load it up into PE10 to cut out commercials or edit, suddenly the audio sounds like something that would be coming out of a rear surround sound speaker and things like an olympic commentator's voice which usually is a primary part of the audio is completely missing.  If I play the clip in the pop-up it is fine but on the timeline or after rendering the sound is totally fouled.  Can anybody explain this?  I defintely can't purchase if this is an issue.
    Aug 20, 2012 5:06 AM   in reply to halodog@
    The Hauppage is the problem. The codecs it uses don't work well with Premiere Elements.
    You can try doing your editing in Windows MovieMaker. It should do what you need to do.
    Aug 20, 2012 11:20 AM   in reply to halodog@
    Premiere Elements is designed for and works great with camcorder video. It's not a particularly good all-purposed editor. Sorry.
    Aug 20, 2012 11:23 AM   in reply to halodog@
    >hauppauge TV card
    What editing software does hauppauge provide to work with their files?
    Aug 21, 2012 3:58 AM   in reply to halodog@
    halodog@ wrote:
      I would imagine there is also a large segment of people like me who also want to edit/compress their HDTV captures so we dont have to deal with commercials and to save hard drive space.
    I doubt that you will be able to retain the HD quality. Because of HDCP most devices down sample to analog for export via component or Scart connector. Having said that, Hauppauge sell the HD PVR, a device that claims to capture HD and will Make Blu-ray compatible AVCHD recordings using its supplied software (Arcsoft Total Media). Note though that it does not contain built-in disk storage so you have to provide your own disk drive.
    Cheers,
    Neale
    Insanity is hereditary, you get it from your children
