How to set up a Bleed and Trim area
Aug 20, 2012 6:10 AM
Tags: #indesign #bleed #cs6 #trim #howto
Hello,
I'm very new to Indesign and still can't get my head around Bleed & Trim. Please advise me how to set up what i'm being asked here;
how to i input that into here;
Many thanks!
    Aug 20, 2012 6:25 AM   in reply to JoshMancey
    The document size is 286x210 and the bleed is 3mm on all four sides. Turn off facing pages.
    If you’re going to use InDesign this is going to be the least of your stumbling blocks.
    I’ll give you my typical newbie advice.
    First, buy Sandee Cohen’s Visual Quick Start Guide. It’s the best beginner book on the planet: http://amzn.to/ORQqtT
    Secondly, check out the videos on Lynda.com. Here’s a link for a free one week trial: http://bit.ly/fcGpiI
    Bob
    Aug 20, 2012 6:55 AM   in reply to JoshMancey
    Set your margins to 16mm all around (or put guides in those postions if you want wider margins). Not sure what this page is for, but they are telling you, badly, that the types hould not extend beyond these points.
    Aug 20, 2012 7:05 AM   in reply to JoshMancey
    Trim Size = width and height in the New Document dialog box.
    286 x 210
    The bleed is an extension of the page where anything that needs to be printed to the edge of a page needs to go into bleed area to allow safe trimming.
    This is 292 x 216
    292-286= 6
    216-210 = 6
    This is on both left and right and top and bottom - divide the results by 2
    So your bleed should 3 mm on all sides.
    Type area is the margins, this is where all the material that doesn't need to extend to the edge of the page needs to go. Anything outside this area may look bad when the final pages are trimmed.
    Your Trim Area is 286 x 210 and the required type area is 254 x 178
    That would mean you set your margins to
    (286 - 254)/2 = 16 mm top and bottom
    (210 - 178)/2= 16mm left and right.
    But this depends on if this is a book? If it's a book it's not a good idea to have even margins - as it will look lobsided when printed and bound.
    I'd talk to your printers about what Margins would be optimal for the layout - if you're not sure yourself.
    Aug 20, 2012 7:13 AM   in reply to JoshMancey
    Keep the margins even. You have no way of knowing if they'll put the ad on a left or right page.  And keep any important image details inside the type area, too, or you'll risk losing them in the binding.
    Aug 20, 2012 7:14 AM   in reply to JoshMancey
    Seem like quite large margins, so you're probably safe. And the designer has 3mm to move the advert left or right depending on the position in the magazine if needs be.
    Aug 20, 2012 7:18 AM   in reply to JoshMancey
    Yeh you should be good to go.
    Anything that needs to go to the edge of the page needs to extend to the bleed line (red line)
    Anything like text or anything that is not going to the edge of the page sits in the margins, 16mm away from the edge of the page.
    Aug 20, 2012 8:06 AM   in reply to JoshMancey
    You can put objects outside the margins, but you want to stop anything that doesn't bleed far enough away from the page edge so it looks deliberate rather than like something that was supposed to bleed, but doesn't.
