8 and 16 bits in grayscale alpha channel
Aug 20, 2012 4:43 AM
Tags: #grayscale #alpha_channel #8_bits_per_channel #16_bits_per_channel
Hello.
When I have an image in 8 bits per channel, its grayscale alpha channel is in 8 bits (256 levels).
But when I have an image in 16 bits per channel, is its grayscale alpha channel in 16 bits (32.768 levels)? They are a lot to make a selection...
    Aug 20, 2012 5:40 AM   in reply to currobegbeg
    Be aware that Selections are 8bit.
    Edit: Which means that you will get differnt results
    • if you load the Channel as a Selection and apply it as a Layer Mask and
    • if you copy the Channel’s content and paste it into a Layer Mask –
    though the difference may seem imperceptible.
  • Noel Carboni
    Dec 23, 2006
    Aug 20, 2012 6:40 AM   in reply to currobegbeg
    Just to be numerically accurate, it's 0x0000 through 0x8000, so it's really 32,769 levels including pure black and max white.
    -Noel
    Aug 20, 2012 6:45 AM   in reply to currobegbeg
    No, an Alpha Channel in a 16bit image is also 16bit, a Selection is 8bit.
    So if you store a Selection you are storing 8bit data in a 16bit Channel.
    Aug 20, 2012 7:31 AM   in reply to currobegbeg
    Why do alpha channels in 16 bits exist if they are not real?
    They are real, you can copy and paste them into a Layer Mask for example instead of loading them.
    http://forums.adobe.com/message/4597174#4597174
