IND CS 6: Duplicating images makes them look "lighter"?
Aug 16, 2012 9:04 AM
Tags: #problem #indesign #images #print #cs6
Hello
ever since updating to CS6 my Indesign behaves strangely when handling pictures:
Once I duplicate a picture, it seems to loose some of it's saturation, thereby noticably looking "lighter".
This happens with copy/cut paste and alt+drag as well.
Re-embedding the pictures helps, but with 500+ pictures in a document, this is rather painful.
Unfortunately, the phenomenon persists all the way into the final pdf I export for printing.
I tested with both CMYK and RGB Jpgs, Psd & Tifs, with Effects (Multiply) on them and without, the same behavior everywhere.
Here's a screenshot of a duplicated image on top of the original:
I really don't know what it could be, any ideas?
My System is a 15" MacBook Pro with the latest version of Lion running (no Mouintain Lion), and the CS6 is up to date.
Thanks a lot for any input!
Best
L
    Aug 16, 2012 11:40 AM   in reply to ltz31
    Please show us a shot withteh lighter image selected and the Effects panel open and showing.
    Aug 20, 2012 5:25 AM   in reply to ltz31
    Nothing odd there. Is the white background part of the image, or fill on the frame?
    What is the transparency blending space set to?
    Aug 20, 2012 6:35 AM   in reply to ltz31
    Does it look different in Overprint Preview?
    Aug 20, 2012 6:40 AM   in reply to ltz31
    ltz1 please, write more about your:
    preferences>clipboard handling
    view >proof colors
    and edit>color settings
    Aug 20, 2012 6:57 AM   in reply to ltz31
    You said "embedded" in the very first post. Is that really true? How do these images get into ID to start, and then what are you doing?
    Aug 20, 2012 7:06 AM   in reply to ltz31
    Is it resticted to this file, or does it happen in a new file?
    Aug 20, 2012 7:07 AM   in reply to ltz31
    First of all try to reboot .
    Next try to go  to Bridge and synchronize your Creative Suite Color Settings.
    What is going on when you duplicate your lighter image?  It it the same or more lighter?
    Aug 20, 2012 9:49 AM   in reply to ltz31
    Try exporting to .idml. See Remove minor corruption by exporting
    If you haven't done a lot of editing, it will be more effective, most likely, to export from CS5.5 if you can.
