Added text onto form via Acrobat X, modifiable by Reader! How to avoid?
Aug 20, 2012 5:38 AM
Tags: #acrobat #x #pro
I built a PDF form (to be filled by end-user later) using Acrobat X.
IBut had to make a few adjustments and while doing so, I used Acrobat X ('content mode') to add some texts onto the document.
When testing it using Reader, I found that those texts could <edit>, <erase> and <change> the editions made by Acrobat X upon clicking onto those texts!
I do not want end-users to make those changes.  How to <fix> those newly added text boxes so it could be <read only> for end-users filling it using Reader?
I have checked the 'tab' order and it is all fine, so if the end-user presses 'tab' each time they toggle through my form, they should just fill in the box as asked. And so, it would not affect my text but, if end-users prefers to use the mouse to guide them through the form and accidentally click onto my newly added texts then I'll be in trouble.
Please help!!
    Aug 20, 2012 8:56 AM   in reply to Win_Form
    Use Properties, set Document Security so changing not allowed.
  • George Johnson
    Aug 11, 2002
    Aug 20, 2012 10:08 AM   in reply to Win_Form
    I'm assuming you added the text using comments. If that's the case, you can flatten the contents to the text become part of the regular page contents. This is most easilt done using the following free JavaScript-based tool: http://www.uvsar.com/projects/acrobat/flattener/
    Be sure not to flatten the fields, and work with a copy of your form so you don't overwrite it.
    Aug 21, 2012 7:24 AM   in reply to Win_Form
    There are lots a number of options one can set when applying security, You can lock the content layer and allow the end user to fill in form fields and sign the form.
    Note that some 3rd party PDF reader programs and apps do not respect Adobe's password security.
