Whoever had a hand in the ePub output CS6...
Jun 5, 2012 7:35 PM
Thanks for wreaking it.
Coming from CS3 to CS6
Because CS4 got it wrong
CS5 and CS5.5 both although fixing CS4 mistakes broke other things.
List of things that annoy
CS6…
Tried the epub output options based on chapter paragraph style.
I consider this broken although it finally splits the document.
I expected the .xhtml files to be named according to whatever was on the ChapterParagraph Style
Massively disappointed, no point using it. I'll go back to my apple script which splits and places in a book file
Capital letters in Stylesheet name no longer get converted to lowercase (spent 1/2 Hour working this one out) thanks very much.
Carriage returns are included…NOT COOL!!!
Changing the folder name from images to image…NOT COOL!!!
That's everything I've found so far...Mind you I haven't finished cleaning it out of uneeded crap...
I want my CS3 back...OMG what have I done.
/rant
    Jun 6, 2012 5:00 AM   in reply to marcusstringer
    magin-top has been discussed elsewhere, Marcus. I don't have a link handy.
    Depending on who you ask it's either a bug or a feature, but my philosophy remains unchanged...write your own CSS. CS6 makes it very easy to map styles to tags and add as many CSS files as you need.
    If you want to truly get your point across however, I suggest doing it here: https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    Bob
    Jun 6, 2012 2:48 PM   in reply to marcusstringer
    Perhaps it will be changed in a dot release.
    Bob
    Aug 20, 2012 9:00 AM   in reply to marcusstringer
    I am the production department for a medium-sized publisher and need CSS style sheets to survive.  We just upgraded from CS5 to CS6 and I've found that CS6 is practically unusable for epubs!  What is going on Adobe??? I appreciate you are trying to make it easier for individuals to make unique books, but you have royally screwed larger production departments that use series CSS sheets to pump out books.
    1.) What has happened to the list feature?  I used to be able to "apply bullets" and use a paragraph style and things would map beautifully to Unordered Lists.  Now there are extra bullets applied.
    2.) Despite the fact that I have "Keep Overrides" unchecked and use an external style sheet, there are character overrides being applied and they are uniquely named for each one!  There's no way to globally fix this without hours of extra work!
    3.) Each image is being renamed with a unique div class.  So there goes my ability to fomat pictures globally with my tried and true CSS.
    4.) As mentioned above, the capitalization conversion to lowercase disappeared for paragraph styles, but for some unknown reason is maintained in character and object styles. Why the unnecessary change?
    This is a MAJOR headache and I will go back to using CS5 as CS6 is unusable for large scale production. It's fine to move forward with individuals creating books on a small scale, but why delete the options that made those of us creating on a large scale to use our own CSS?
    Please, please, please, please, make a bug fix that allows you to completely bypass the InDesign CSS and attach your own as there was in CS5. This renaming is a version killer and I won't recommend it to anyone.
    Aug 20, 2012 9:11 AM   in reply to KBprod45
    Aug 20, 2012 2:46 PM   in reply to marcusstringer
    You won’t get any argument from me.
    Bob
