Cropping photos in Illustrator
May 5, 2010 1:09 AM
Hello
Is it possible to crop photos in illustrator without moving into photoshop?
    May 5, 2010 1:20 AM   in reply to yikes365
    Yes just mask them with a rectangle on top, select both and select make clipping mask
    May 5, 2010 2:31 AM   in reply to yikes365
    After placing the image, draw a rectangle over the desired portion of the image, then select both and make a clipping mask. With clipping mask, a portion of the image is made visible and the rest is hidden. But if you really want to get rid of the hidden portion of the image, here's a trick.
    - Place the clipped image in a blank area of the document.
    - From the Transparency panel, apply a blending mode to it - say Multiply. As there is nothing beneath, no change in appearance would happen.
    - Now use Object > Flatten Transparency on the image. Remember to choose the right ppi for the raster.
    And here you go, hidden portions of the image get removed. But remember this is a trick.
    - Neeraj
    Aug 20, 2012 9:26 AM   in reply to yikes365
    We've recently created two videos explaining how to do this.
    With Clipping Masks:
    With Opacity Masks:
    I hope you find these videos helpful!
