Copy to new artboard with transformation in VBA
Aug 20, 2012 1:34 AM
Tags: #vba
Hallo Forum,
I have the common problem to resize the artboard to standardize technical illustrations to the format 50x50mm. So I found good help in the forum (thank you). I have some problem and may somebody can help me:
  • I would like to group the objects for further transformations
  • I would transform the group to 45mm and scale stroks and effects
N.B.: here It should be a test on landscape format
  • I would align the group to the page center
This is my code, may somebody can help me ?
Thank you to every replay
Regards Alex
Public Sub copy_paste_with_transformation ()
'Duplicates grouped items in a new document with landscape sensitive transformation
Set appRef = CreateObject("Illustrator.Application")
'calculate the size of objects do define if it's landscape or not
Bounds = appRef.ActiveDocument.VisibleBounds
'If the group is landscape the lenth should be 45mm otherwise the higth
appRef.ActiveDocument.GroupItems 'problem
appRef.ActiveDocument.SelectObjectsOnActiveArtboard 'may a solution for CS4 too
appRef.ActiveDocument.Resize(45, 45) 'problem
appRef.ActiveDocument.copy
Set newDocument = appRef.Documents.Add(aiDocumentCMYKColor, 50, 50) 'Paper size is 50mm
newDocument.Paste
'Align group to page center hrizontal and vertical
End Sub
    Aug 20, 2012 11:15 AM   in reply to alexanderklapfer
    Im sorry I don't do VB ( a mac thing ) don't you just need translate x&y by some little math? Paste should put it at window centre… Have you tried changing the view?
    Aug 21, 2012 7:38 AM   in reply to alexanderklapfer
    Not in VB ( klingon ) but ExtendScript… May be you can look this up and translate?
    #target illustrator
    newDocGroup();
    function newDocGroup() {
              var mm = 2.83464567, grpFile, doc, scale;
              grpFile = File( Folder.desktop + '/Testing.ai' );
              doc = app.documents.add( DocumentColorSpace.CMYK, 50*mm, 50*mm );
              doc.groupItems.createFromFile( grpFile );
              if ( doc.pageItems[0].width >= doc.pageItems[0].height ) {
                        scale = ( 45*mm / doc.pageItems[0].width ) * 100;
              } else {
                        scale = ( 45*mm / doc.pageItems[0].height ) * 100;
              doc.pageItems[0].resize( scale, scale, true, true, true, true, scale, Transformation.CENTER );
